Gerry Posted March 7, 2007 Share Posted March 7, 2007 OK I know I'm dumb.... Had new UK brakes on the front for about 2,000 miles. Should the pads be loose in the calipers, I am able to wriggle them and make them clunk slightly ? Thanx..... G Link to comment Share on other sites More sharing options...
merckx Posted March 7, 2007 Share Posted March 7, 2007 They may move only very slightly. There should be a spring clip that's fastened around the two pins, this clip pushes against the pads to hold them tight. The pins obviously go through the two holes which are in each of the pads backing plates. Link to comment Share on other sites More sharing options...
