supradibbs Posted July 16, 2004 Share Posted July 16, 2004 Amber traction control off light keeps flashing on and off any ideas????????????? Quote Link to comment Share on other sites More sharing options...
Darren Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by supradibbs Amber traction control off light keeps flashing on and off any ideas????????????? Wheels spinning??!! Quote Link to comment Share on other sites More sharing options...
Justin Posted July 16, 2004 Share Posted July 16, 2004 TRAC OFF button pushed in? Not being funny mate but you never know Could be the fuse is out or blown. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by supradibbs Amber traction control off light keeps flashing on and off any ideas????????????? Do you have RLTC? If you don't have RLTC, try resetting the ECU and/or checking the speedo converter. Also, I had a similar problem with a bad earth connection on the SLD Quote Link to comment Share on other sites More sharing options...
Justin Posted July 16, 2004 Share Posted July 16, 2004 If he has got RLTC then he had the wrong dat file loaded at Pod. Sorry mate not funny. Ducks. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by Justin If he has got RLTC then he had the wrong dat file loaded at Pod. LOL! That's cruel! Quote Link to comment Share on other sites More sharing options...
supradibbs Posted July 17, 2004 Author Share Posted July 17, 2004 nice one chaps as advised by dude checked and changed fuse removed restted plug to the switch the switch does not seem very positive like there is no click if you know what i mean cant remember if this is normal or not The car has been standing for a while and picked it up from the body shop yesterday and it was doing this was not doing it when i took it to them iam a bit stumped!!!!!! Quote Link to comment Share on other sites More sharing options...
supradibbs Posted July 17, 2004 Author Share Posted July 17, 2004 oh i do not have RLTC Quote Link to comment Share on other sites More sharing options...
SimonB Posted July 17, 2004 Share Posted July 17, 2004 It flashes like this to tell you it's not working for some reason. You could check the connectors to the trac butterfly motor and position sensor under the bonnet. They are at the front of the throttle body each side just where the pipe from the intercooler comes in. Oh, and the plug that goes into the trac ECU, which is next to the main ECU under the cover in the passenger footwell. The switch doesn't click normally, so that's OK. Quote Link to comment Share on other sites More sharing options...
mr keef Posted July 18, 2004 Share Posted July 18, 2004 mine done this a while ago,then 2 days later it went off and is now normal. Quote Link to comment Share on other sites More sharing options...
