Steve W Posted March 31, 2002 Share Posted March 31, 2002 Has anybody RESET their Airbag Light using the method on mkIV.com i.e. Shorting-Out AB + TC connections in plug alternately ?? Don't want to start shorting things out UNWISELY... Do they mean do it with the ignition ON or OFF ? [They say "watch the light while your doing it"] Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 31, 2002 Share Posted March 31, 2002 Never done it, but i know plenty of people who have and it works fine. I guess it would be with the ignition on. Quote Link to comment Share on other sites More sharing options...
Steve W Posted March 31, 2002 Author Share Posted March 31, 2002 Thanks Martin, I'll wait till someone has definitely done it (more annoying than anything - my head's not going anywhere in an accident anyway, it's touching the roof as it is !!) Don't fancy sticking the wires-in-holes till someone on here says: "It didn't go BANG". Quote Link to comment Share on other sites More sharing options...
Guest Mycroft Posted March 31, 2002 Share Posted March 31, 2002 I don't know about supras being any different but I have reset a Soarers without hassle. Iused an electronic metronome to ensure it worked first time. Quote Link to comment Share on other sites More sharing options...
GavinL Posted March 31, 2002 Share Posted March 31, 2002 Quote: from Steve W on 8:28 pm on Mar. 31, 2002[br]Thanks Martin, I'll wait till someone has definitely done it (more annoying than anything - my head's not going anywhere in an accident anyway, it's touching the roof as it is !!) Don't fancy sticking the wires-in-holes till someone on here says: "It didn't go BANG". Yes, I have done it no problem. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 31, 2002 Share Posted March 31, 2002 Quote: from Mycroft on 8:31 pm on Mar. 31, 2002[br]I don't know about supras being any different but I have reset a Soarers without hassle. Iused an electronic metronome to ensure it worked first time. What you let your Soarer listen to a monotonous tick tock ?? Or do you mean an astable circuit ? Quote Link to comment Share on other sites More sharing options...
Guest Mycroft Posted March 31, 2002 Share Posted March 31, 2002 ? Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 31, 2002 Share Posted March 31, 2002 Wow................Lord Mycroft....................speechless!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Guest Mycroft Posted March 31, 2002 Share Posted March 31, 2002 No, I mean an electric metronome. Thank you Comrade F. (Edited by Mycroft at 10:34 pm on Mar. 31, 2002) Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 31, 2002 Share Posted March 31, 2002 So how is something sitting there going tick-tock going to reset your airbag light ? Pray tell. Quote Link to comment Share on other sites More sharing options...
Guest Mycroft Posted March 31, 2002 Share Posted March 31, 2002 Because if you switch the on-off sequence either too quickly or too slowly then it doesn't accept the the code, it has to be 'in time' to the OBD clock, you can set this by switching on the A/C diagnostics set the 'nome to that then go do the job. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 31, 2002 Share Posted March 31, 2002 Yawn...what a way of over complicating a simple process. Here is a link to the process that most people seem to use successfully. http://www.mkiv.com/techarticles/airbag_light/airbag.htm Quote Link to comment Share on other sites More sharing options...
Guest Mycroft Posted April 1, 2002 Share Posted April 1, 2002 As I read that it says 'this has to be done several times' well if you use a 'nome you do it once...correctly. Quote Link to comment Share on other sites More sharing options...
Steve W Posted April 1, 2002 Author Share Posted April 1, 2002 Martin, THAT is where I read the thing in the first place... [Caught my eye as my AB light's been on since I got the car!] Mycroft(?), Do you a) Disconnect battery during resetting. b) Battery connected, BUT ignition OFF. c) Ignition ON, ie. so you can see AB light ? Steve. Quote Link to comment Share on other sites More sharing options...
GavinL Posted April 1, 2002 Share Posted April 1, 2002 Quote: from Steve W on 8:33 am on April 1, 2002[br]Martin, THAT is where I read the thing in the first place... [Caught my eye as my AB light's been on since I got the car!] Mycroft(?), Do you a) Disconnect battery during resetting. b) Battery connected, BUT ignition OFF. c) Ignition ON, ie. so you can see AB light ? Steve. I just turned the ignition on. Then I got my wife(any old wife you happen to have lying around will probably do) to watch the light and . shout when it went out. regards..... Quote Link to comment Share on other sites More sharing options...
Steve W Posted April 1, 2002 Author Share Posted April 1, 2002 Thanks Gavin, I'll go out right now and give it a try.. [Well I'll put some 'strides' on first !!] Is there a connector by the 'fire-wall' as the article says or do you have to use the one beside the inlet plenum chamber ?? Steve Quote Link to comment Share on other sites More sharing options...
GavinL Posted April 1, 2002 Share Posted April 1, 2002 Quote: from Steve W on 9:55 am on April 1, 2002[br]Thanks Gavin, I'll go out right now and give it a try.. [Well I'll put some 'strides' on first !!] Is there a connector by the 'fire-wall' as the article says or do you have to use the one beside the inlet plenum chamber ?? Steve the latter as I recall, it's got flip up lid so it's quite easy too find. Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted April 1, 2002 Share Posted April 1, 2002 Okay There isn't the same box on an NA.......has anyone reset their airbag light on an NA? Quote Link to comment Share on other sites More sharing options...
Steve W Posted April 1, 2002 Author Share Posted April 1, 2002 WELL... Tried it this morning with mate watching light, TC-AB-TC-AB about 10 times and it flickered THEN off.... Comes on with ignition and goes out after ~5 seconds (sounds OK ? like a 'check light' ?) [ side-track >>>] Then spent rest of the day RIPPING front speakers out of the depths of the doors and putting 6.5" ON the doors - had to carve great holes out of each of the 'boxes' BUT left the basic shape of the box just because the window 'guide runs up+down a groove in the box. THE DIFFERENCE IN QUALITY IS REALLY, REALLY WORTH THE AG' OF DOING THE JOB. Now it shows the rear speakers up quite badly - I've had to bias most to the front otherwise you NOTICE the sound from the back (EERRGGHH!). [back-on-track >>] UNFORTUNATELY, after doing all that I've just started the car to make sure I hadn't run the battery down and THE BLOODY AIRBAG LIGHT SEEMS BE ON AGAIN ?!?!?! (Edited by Steve W at 5:53 pm on April 1, 2002) Quote Link to comment Share on other sites More sharing options...
Guest Mycroft Posted April 1, 2002 Share Posted April 1, 2002 Wanna borrow a metronome? Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 1, 2002 Share Posted April 1, 2002 :biggrin: Made me smile!!! (both the comment and the new signature!) Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 1, 2002 Share Posted April 1, 2002 Quote: from Steve W on 5:52 pm on April 1, 2002[br] UNFORTUNATELY, after doing all that I've just started the car to make sure I hadn't run the battery down and THE BLOODY AIRBAG LIGHT SEEMS BE ON AGAIN ?!?!?! (Edited by Steve W at 5:53 pm on April 1, 2002) Did you trun the ignition on whilst you had the top part of the dash disconnected at all ? This is what trips the airbag light. Mind you i guess with the multitude of problems you have been experiencing a loose plug behind the dash would not be out of the question! Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 1, 2002 Share Posted April 1, 2002 Quote: from Mycroft on 6:10 pm on April 1, 2002[br]Wanna borrow a metronome? Your lordship I think the fact that Steve has managed it once without some poncy bit of kit proves how easy it is! But hey what do i know. We are not worthy!!! http://www.stopstart.fsnet.co.uk/mica/chimp.gif (Edited by Martin F at 8:31 pm on April 1, 2002) Quote Link to comment Share on other sites More sharing options...
Steve W Posted April 1, 2002 Author Share Posted April 1, 2002 No... I only did the door speakers after turning it off. Didn't touch the dash or top-light-'rail'. EITHER there really IS an airbag fault OR you need to do it a couple of times ?? OR as you say, a loose plug to top-left-cluster. Quote Link to comment Share on other sites More sharing options...
Guest Mycroft Posted April 1, 2002 Share Posted April 1, 2002 I thought the point was...he hadn't...the damn thing is still blinking! Would you like a banana.....for the monkey that is. Quote Link to comment Share on other sites More sharing options...
