Guest Morgan Posted March 6, 2007 Share Posted March 6, 2007 When fitting micro LED lights in the footwell, I managed to touch positive / negative wires and blew the fuse. Problem is that I can't find the fuse! I have looked in the fuse boxes under the bonnet and in the drivers footwell and can't find a fuse for this circuit. ANY IDEAS? I recall that the footwell lights , the light around the ignition key hole and the drivers door key hole light all have a delay and are all on this circuit ( the only lights with a delay on the Supra I think) could there be a delay /timer module somewhere that I have bust? Can anyone HELP. THANKS Link to comment Share on other sites More sharing options...
bolarbag Posted March 6, 2007 Share Posted March 6, 2007 whats actually workin mate?Are your dash lights working...Odometer e.t.c? There is a seperate fuse for Odometer Lights and a seperate fuse for the leds in the Air cn e.t.c Link to comment Share on other sites More sharing options...
Kieran Posted March 6, 2007 Share Posted March 6, 2007 The fuse for the footwell lights is an in-line one and is in a yellow barrel in the drivers footwell - it's a 1A glass fuse. Never noticed if it's connected to the ignition light as well though. Link to comment Share on other sites More sharing options...
Kieran Posted March 6, 2007 Share Posted March 6, 2007 Didn't really explain that too well, the fuse is tucked away behind the dash panel under the steering wheel, not near the fuse box in the footwell. Link to comment Share on other sites More sharing options...
Guest Morgan Posted March 6, 2007 Share Posted March 6, 2007 Have checked the yellow cased line fuse and it's OK As far as I can see there are two leads out of the wiring loom behind the dashboard, the yellow cased line fuse is close to where the two leads come out of the loom, after the line fuse they split to feed each footwell light, the ignition key illumination light and the drivers outside door keyhole light.They all do not work.The interior lights , dash and everything else is working What about the module for the delay on these lights which go off a few seconds after the door is closed, unlike the main interior roof lights which go out as soon as the door is closed (I think).Anybody know if there is a module/unit to do this? Could i have broken/blown this and thats why its all now dead. I have checked for power before the yellow line fuse and there is no power up line from the fuse? Hope someone can help. Link to comment Share on other sites More sharing options...
Kieran Posted March 6, 2007 Share Posted March 6, 2007 The wiring diagrams are in this thread. Have a look at page 33 of the system wiring diagrams, looks like there's a unit all the lights go to. No idea where it is though. Link to comment Share on other sites More sharing options...
TrickTT Posted March 7, 2007 Share Posted March 7, 2007 The interior lights are fused under the bonnet 5amp ( i think) listed as "Dome" on the fusebox lid. Link to comment Share on other sites More sharing options...
Mike M Posted March 7, 2007 Share Posted March 7, 2007 The interior lights are fused under the bonnet 5amp ( i think) listed as "Dome" on the fusebox lid. That's the one I blew as well as the inline fuse when fitting the footwell LED bulbs. It's an orange 7.5A DOME. Link to comment Share on other sites More sharing options...
