BL Ready To Rock
terribleturner
Guest Terry S
Just a little modified then!
Where's the IC? It looks like the pipe from the compressor goes round the back of the engine and into a throttle body on the BACK of the intake?
Passenger footwell.
Don't think they have said yet but you can see the purple of the TB at the back of the plenum. And i belive they may have a cold air system sat in the passenger seat. Possibly similar to.....
http://gmhightechperformance.com/features/0507htp_seven_16_z.jpg
Guest Terry S
It's not a cold air system it's an A2W intercooler.
Very, very interesting. What ignition system is it running? Also no taper on the inlet plenum that you see on most of the mass produced ones, have bl hit on something or is it just a case of it shoves that much air in there it dosent matter about flow
Think it's just a dyno queen, but im sure if im wrong Terry will be here in a flash to correct :)
You're starting to sound like Paul E :D
Colours are based on this bad boy :D
On that car (A Chevy Chevelle if I'm not mistaken), the colours work, but it just looks odd on a supra.
