Best size Doluck wheels for UK supra?
AntD
Recommended supra fitment with standard arches is Front: 18 x 9 et +35. Rear: 18 x 10.5 et +44.
There are some pics in my garage.
I've had the following recommendation from Sumo Power as per the Do-Luck Supra :
Front 18 x 9.0 +35mm 235-40-18
Rear 18 x 10.5 +35mm 265-40-18
I just need some views on this fitment before I order my Do-Lucks from Gaz at Envy:conf:
We'd run different offsets and tyres sizes to that Ant. For the rear tyre you want a 275/35/18 or a 285/35/18.
Regards,
Gaz.
Front is ok although i run a 245/40/18 tyre.
A 265 rear is too narrow for a 10.5" rim IMHO, but if you put a +35ET rear on, you will have clearance issues with a 275 or 285 tyre
What other option is there to that rear offset as mine foul the arches with 275*30
Right,so far I've got these specs finalised:
18 x 9.0 +35 245-40-18 front
18 x 10.5 ? 275-35-18 rear
I basically want an offset at the rear that will show a deep lip on the face of the wheel.I won't mind if minor archwork is necessary.
Thanx for your input guys
