Homer Posted July 15, 2004 Share Posted July 15, 2004 Planning on installing my shiny new Walbro pump tomorrow, but I'm unsure how to get one of the fittings off. Could anyone tell me how to get the little item circled detaches from the assembly? It looked like its just a bolt but it just didn't seem to want to move Though it best to ask here before I break something! Also, are there any things I should be wary of? (Already know about staggering the wires and of course, not smoking ) Quote Link to comment Share on other sites More sharing options...
matt Posted July 15, 2004 Share Posted July 15, 2004 Try anticlockwise:p Quote Link to comment Share on other sites More sharing options...
Jake Posted July 15, 2004 Share Posted July 15, 2004 It's a union bolt (at least I think that's what they're called). Just undo it like a regualr bolt, it's tight though. Then take off the fuel pipes and the huge jubilee clip, then unscrew that big plastic ring. That's the most difficult bit, I had to beat it round with a socket extension and a hammer. Quote Link to comment Share on other sites More sharing options...
Homer Posted July 15, 2004 Author Share Posted July 15, 2004 Thanks, guess I'll give it a bit more force! Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted July 15, 2004 Share Posted July 15, 2004 also isnt it wise to open the fuel cap to de pressurize the fuel so it wont spurt out when undoing the clips?? Quote Link to comment Share on other sites More sharing options...
Jake Posted July 15, 2004 Share Posted July 15, 2004 Sounds like a good idea, Emin. I wish I'd known that when I did mine. Quote Link to comment Share on other sites More sharing options...
SimonB Posted July 15, 2004 Share Posted July 15, 2004 Yep, and take the fuel pump fuse out (or the connector to the pump) and crank the engine a few times to depressurise the line a bit too... Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 15, 2004 Share Posted July 15, 2004 Or just undo it and mop the fuel up with bogroll -Ian Quote Link to comment Share on other sites More sharing options...
paul mac Posted July 15, 2004 Share Posted July 15, 2004 leave the car for about 20 minutes after switching the engine off as they hold the pressure for quite a while, this should avoid spillage, when re-fitting the big plastic ring put some silicone grease on it or washing up liquid (anything non petroleum based) it should then p**s on rather than having to knock s**t out of it all the way round, and be carefull with it being plastic it is easy to cross thread, i seem to remember having to do a bit of bending of the metal bracket that holds the pump as it did'nt line up Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by Ian C Or just undo it and mop the fuel up with bogroll -Ian That's the method I use... Works every time You hardly get any real spill anyway. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by paul mac when re-fitting the big plastic ring put some silicone grease on it or washing up liquid (anything non petroleum based) it should then p**s on rather than having to knock s**t out of it all the way round Sound advice here but don't grolly the thing on with said lubricant applied cos over time that lubricant will work its way out and any subsequent removals will be thwarted cos you tightened it too much. In fact don't use washing up liquid cos that in itself turns into a gluey substance over time. A bit of the old vaseline should be a better idea if you experience tightening problems. Quote Link to comment Share on other sites More sharing options...
SimonB Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by dangerous brain A bit of the old vaseline should be a better idea if you experience tightening problems. Is that your normal advice there Brian? Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by SimonB Is that your normal advice there Brian? Well if we are gonna drag this thread down then I would go with some KY lol but that would be more for pushing into tight spaces than screwing into reluctant threads;) Quote Link to comment Share on other sites More sharing options...
Justin Posted July 16, 2004 Share Posted July 16, 2004 PMSL :D Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by Loid Planning on installing my shiny new Walbro pump tomorrow, but I'm unsure how to get one of the fittings off. Could anyone tell me how to get the little item circled detaches from the assembly? It looked like its just a bolt but it just didn't seem to want to move Though it best to ask here before I break something! Also, are there any things I should be wary of? (Already know about staggering the wires and of course, not smoking ) PS that plastic ring nut thingy that holds the fuel tank top in will be the hardest thing to undo. I had to muller the crap out of mine with a hammer and drift to get it to undo. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 16, 2004 Share Posted July 16, 2004 Originally posted by dangerous brain PS that plastic ring nut thingy that holds the fuel tank top in will be the hardest thing to undo. I had to muller the crap out of mine with a hammer and drift to get it to undo. I already said that Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted July 16, 2004 Share Posted July 16, 2004 Oh pooooeee up ur bung hole lol. I blow a raspberry in ur general directiiiioooonnnnnnnn Quote Link to comment Share on other sites More sharing options...
Homer Posted July 17, 2004 Author Share Posted July 17, 2004 Thanks to all for the help guys, the pump went in fine today. That plastic ring thingy sure is a bugger to get off! ...and no more poping noises at WOT anymore! Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted July 17, 2004 Share Posted July 17, 2004 Originally posted by Loid Thanks to all for the help guys, the pump went in fine today. That plastic ring thingy sure is a bugger to get off! ...and no more poping noises at WOT anymore! what way did you wire the pump up. theres supposed to be a few ways you can do it. does anyone have a pic of what all the pipes are for which is fuel output to injector rail. which is fuel return line Quote Link to comment Share on other sites More sharing options...
Homer Posted July 17, 2004 Author Share Posted July 17, 2004 I cut the existing wires and used the butt splices supplied to connect up the new harness. Seemed to do the trick! Didn't realise there was an alternative? Quote Link to comment Share on other sites More sharing options...
Jake Posted July 17, 2004 Share Posted July 17, 2004 Originally posted by Loid I cut the existing wires and used the butt splices supplied "butt splices supplied "? There wasn't anything like that suppied with the pump I got from Paul E Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted July 17, 2004 Share Posted July 17, 2004 Think I am gonna need an upgrade fuel pump for this n2o kit i have sat next me. Was gonna stick it on me barge but having warped the heads on it once I will be giving that a miss now and will whack it on the supe instead. Quote Link to comment Share on other sites More sharing options...
Homer Posted July 17, 2004 Author Share Posted July 17, 2004 I got mine from Terry so not sure if they're the same... The kit had: - pump & filter & retainer - 2x butt splices - wiring harness - fuel pipe - 2x jubeliee clips - isolator The splices were certainly part of the pack, think this kit came from the states originally... Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted July 18, 2004 Share Posted July 18, 2004 heres a pic i took of the WALBRO 341 with supra fitting kit. got 2 from america for about £65-70 each WALBRO 341 fuel pump picture Quote Link to comment Share on other sites More sharing options...
