The space saver wheel?
wHIZz
Hi, not been on for a while (been getting married 'n stuff! :p )
What is the consensus on using the Supra space saver wheel? - I've got aftermarket 18" alloys and if using the space saver is a no-no with 18's I may as well take it out and use the space in the boot for my amps and subs?
Any advice? :search:
Thanks
wHIZz
I have 18's and have had to use the spacesaver twice when I broke valves. It does what it says, it gets you home, luckily only 8 and then 24 miles. Its pretty frightening even at 50 and even then you have to slow for corners. But it gets you there
