Marty Posted March 2, 2007 Share Posted March 2, 2007 Got bit of a strange idle problem with the supe. Its only just started doing this in the last week, since the battery died, not that im convinced its linked, the ecu's had time to sort itself out etc. Basically, it wont idle. I'll start it, and unless i hold the revs on with the throttle, it dies. Also, when i am holding the revs on using the throttle, it wont hold a constant rev, it constantly varies up and down +/- 500rpm. Maybe an idle control valve issue? Also as i say, was fine last week. Im still trying to sort out my afr's etc, but i dont think this could be the problem, its running a lil bit rich but staying above 11.5ish all the time. Any ideas? Ive done a bit of a search but cant find any similar problems Quote Link to comment Share on other sites More sharing options...
turbonut Posted March 2, 2007 Share Posted March 2, 2007 Got bit of a strange idle problem with the supe. Its only just started doing this in the last week, since the battery died, not that im convinced its linked, the ecu's had time to sort itself out etc. Basically, it wont idle. I'll start it, and unless i hold the revs on with the throttle, it dies. Also, when i am holding the revs on using the throttle, it wont hold a constant rev, it constantly varies up and down +/- 500rpm. Maybe an idle control valve issue? Also as i say, was fine last week. Im still trying to sort out my afr's etc, but i dont think this could be the problem, its running a lil bit rich but staying above 11.5ish all the time. Any ideas? Ive done a bit of a search but cant find any similar problems I've had similar problems with my NA, was given this link by another member, hope it helps: http://www.mkivsupra.net/vbb/showthread.php?t=67386&highlight=ICV good luck with sorting it Quote Link to comment Share on other sites More sharing options...
Marty Posted March 2, 2007 Author Share Posted March 2, 2007 I've had similar problems with my NA, was given this link by another member, hope it helps: http://www.mkivsupra.net/vbb/showthread.php?t=67386&highlight=ICV good luck with sorting it ooh, thanks I'll wip it off and have a look at it Gives me something to do today at least Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 2, 2007 Share Posted March 2, 2007 ooh, thanks I'll wip it off and have a look at it Gives me something to do today at least If you look at Tlicense "blitz twin installation thread (im always recommending that thread ) he has a few pictures of the IAC and the correct orientation to refit the rubber gasket and little valve If you forget. Quote Link to comment Share on other sites More sharing options...
bondango Posted March 3, 2007 Share Posted March 3, 2007 Though it usually wont make the car stall, it may be worth investigating the o2 sensor, have had the bad haunting revs on tickover and usually turned out to be the oxy sensor. Maybe worth following up if the ICV works out ok. Marty Quote Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted March 3, 2007 Share Posted March 3, 2007 dodgy tesco petrol:d Quote Link to comment Share on other sites More sharing options...
