Hi Guys, newbie here with a couple of questions
DamanC
Yes, this isn't being made very clear.
The UK version is simply... the UK version. There is no direct equivalent J spec (or 'import'). The top of the range J spec is the GZ. This has all the gadgets, but is still slightly below the UK version (no heated seats, headlamp washers, etc).
Disappointingly, no one has mentioned the FAQ forum yet. If you go here..
http://www.mkivsupra.net/vbb/forumdisplay.php?s=&forumid=14
...you will find discussions on UK versus J Spec (which includes info on the differences between them), auto v manual, and pre- and post-facelift differences. Also some useful 'what to look for when buying' advice.
  • 2 weeks later...
Originally posted by DamanC
typical newbie question, but what does BBS stand for? (please dont laugh) :stupid:
BBS stands for Bulletin Board System. This is really a forum. BBS's were the ANSI-based terminal systems that people used to dial-in to using their modems - PCBoard, RemoteAccess, System-X, Ami-X, MajorBBS/Worldgroup etc.
hello
i have a supra twin turbo mine is a early model (93).
Before the supra i had a saxo vts like you and it was quick the best quarter mile time i got was 15.03 but the supra is in a different class. i test drove a couple of n/a's and the in gear acceleration was so much better than the saxo.
I then decided on a twin turbo as i knew i would get hungry for more power eventually.
The handling is also better with the soop, the only area that isn't brilliant is the braking but that can be sorted with a uk brake upgrade.
Servicing costs for the soop are also very reasonable and are less than i was paying for the saxo.
Get one dude you will not regret it.
