Replacement Clear Headlight Lens (Merged)
suprattgaz
  • Replies 270
  • 1 year later...
I fitted mine a couple of weeks ago, after the lenses sat in my shed for nearly six years lol. It was a painful process as my lenses were off the original buy with no inserts, just the face of the lens, so I had to use a dremmel to cut the lip off a set of donor lenses, then bond the new lenses to the lips and re-fit. It took hours but was SO worth it in the end, kicking myself for not doing it sooner as they look so good. Have pics but can't upload them from work, will fire some up later.
I really need to crack on with this I was in talks with a plastics moulding company that said they could make me the complete lense. So that it would be a direct replacement (no chopping of the originals) but dropped the bomb shell of the cost of the tooling at 10k so I soon dismissed that. Looking into other routes at the min though.
  • 2 years later...
I looked into getting some propper injection moulds made but they wanted mega money. I also looked into sourcing toyota's original headlight moulds but just kept hitting dead ends, which was a bummer.
I still have the moulds here but it's not just a straight forward swap for your original lense. You have to cut and bond the new lense to your original lense which isn't to everyone's taste unfortunately.
I'll see what I can do.
They've got weird hairline fractures all through out them like they've been put under stress or heated and cooled too quick. I've tried re-furb but its actually in the plastic :(
They're stress fractures, and it is a common issue with many plastic headlights, not just Supras. The only supra headlights that will never suffer them are the UK ones.
For the price mate I'd personally just look for a good condition used set of glass ones.
i have a set of these clear lenses with the tricky work done and bonded to a set of painted facelift lights, (you have to cut up the original lenses its a real pain to do) they need properly refurbing and going around seals with sealant to be watertight, but the actual plastic lenses are perfect, i got sick of faffing with them so bought some new facelifts. if anyone wants a project they could have a very rare and unique set of lights, pop me a PM if you want to make me a decent offer :-)
Would love a set of clear ones if someone started making them again :)
Still on going with it fella, shouldn't be too long now and i may have a solution to it, but if not i shall be able to reproduce the clear lense cut and shut like the original group buy pretty soon hopefully. I will have to speak to a mod first though.
