Guest Phillw454 Posted February 27, 2007 Share Posted February 27, 2007 Iv got a 7" tv/dvd monitor to go in my car, but it hasnt got a connector on it, just loose wires with tags on for what they are. So it needs one of them connector things from halfords and then fitted into my double din slot so il need to get a pocket for it. I dont really want to take it to sextons cause theyl charge me a bomb, so is there anyone around the southwest that fancies earning a few quid fitting this for me on the weekend? Link to comment Share on other sites More sharing options...
uksupra Posted February 27, 2007 Share Posted February 27, 2007 goto halfords ask for a female iso block with open ended wiring... this will or should have the relevant colored wires that should match up to the wires on the back of your screen... yellow (positive permanent) red (ignition )etc... then get a supra to iso adaptor harness... the supra to iso harness will match the supra wires to the standard iso block on a male iso connector... the male iso then plugs into teh female iso that you will connect to the wiring on your screen.. sorted Link to comment Share on other sites More sharing options...
Al Massey Posted February 27, 2007 Share Posted February 27, 2007 why go thru all that bother,he only needs one iso connector(one that fits a supra) and just connect the wires together,but remember to change the red and yellow wires around so you keep your memory, i live in warminster if you really need a hand Link to comment Share on other sites More sharing options...
uksupra Posted February 27, 2007 Share Posted February 27, 2007 well my way just turns your standard radio wires into an iso connection instead of limiting the radio to be supra fitment only Link to comment Share on other sites More sharing options...
Kev.O Posted February 27, 2007 Share Posted February 27, 2007 Iv got a 7" tv/dvd monitor to go in my car, but it hasnt got a connector on it, just loose wires with tags on for what they are. So it needs one of them connector things from halfords and then fitted into my double din slot so il need to get a pocket for it. I dont really want to take it to sextons cause theyl charge me a bomb, so is there anyone around the southwest that fancies earning a few quid fitting this for me on the weekend? Where about's in Avon are you mate? Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted February 27, 2007 Share Posted February 27, 2007 Bristol, just by the suspension bridge Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted February 27, 2007 Share Posted February 27, 2007 why go thru all that bother,he only needs one iso connector(one that fits a supra) and just connect the wires together,but remember to change the red and yellow wires around so you keep your memory, i live in warminster if you really need a hand Ok ta il have a look:) Link to comment Share on other sites More sharing options...
edge Posted February 27, 2007 Share Posted February 27, 2007 Iv got a 7" tv/dvd monitor to go in my car, but it hasnt got a connector on it, just loose wires with tags on for what they are. So it needs one of them connector things from halfords and then fitted into my double din slot so il need to get a pocket for it. I dont really want to take it to sextons cause theyl charge me a bomb, so is there anyone around the southwest that fancies earning a few quid fitting this for me on the weekend? Bring it over to me if you like. I wont even charge you aslong as you make the tea. Plus theres a halfords up the road to me. Link to comment Share on other sites More sharing options...
Al Massey Posted February 27, 2007 Share Posted February 27, 2007 Ok ta il have a look:) im free this weekend if ya need a hand,iv prob got all the bits ya need as iv got loads of stereo stuff lying about Link to comment Share on other sites More sharing options...
Kev.O Posted February 27, 2007 Share Posted February 27, 2007 I live near Frampton Cotterell, and will be working in Avonmouth on saturday. I don't mind giving you a hand if you like! Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted February 27, 2007 Share Posted February 27, 2007 Thanks all, il have a look asap and see if i even wana attempt it, if not im sure il drag one or more of you out to have a look:d Link to comment Share on other sites More sharing options...
JODY T Posted February 27, 2007 Share Posted February 27, 2007 Phil give me the wireing and the halfords adapter and Ill cut and solder it all together for you... once thats done, itll fit easy... Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted February 28, 2007 Share Posted February 28, 2007 Phil give me the wireing and the halfords adapter and Ill cut and solder it all together for you... once thats done, itll fit easy... Sounds like a plan, you free anytime soon? iv got 1 din box but i might need another one, to be honest i dont know if the radio is ment to fit into it or not Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted March 4, 2007 Share Posted March 4, 2007 Right i got a loom from halfords and have connected it all up. But i have 6 spare wires, 3 from the halfords loom and 3 from the headunit loom The 3 spare from the halfords loom are (this is what it says on the wire) Black earth Orange illumination Yellow memory The 3 spare from the headunit loom are Orange back ward Orange and black parking Brown phone mute These is also a fuse box with a earth and positive on it so that seems straight forward. Just wondering what i should do with the spare wires. Leave them or try to connect them? Someone please help!!!!! Will drive me mad otherwise! Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted March 4, 2007 Share Posted March 4, 2007 anyone? Link to comment Share on other sites More sharing options...
