Tricky-Ricky Posted February 27, 2007 Share Posted February 27, 2007 Anyone have a short about 6" piece of 38mm ID blue silicone hose? Link to comment Share on other sites More sharing options...
Guest mk47 Posted February 27, 2007 Share Posted February 27, 2007 i have some blue hose not sure on the diameter though will check when im home. if its what you need ill send it over mate Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 27, 2007 Author Share Posted February 27, 2007 Thanks mate, much appreciated:) Link to comment Share on other sites More sharing options...
Guest mk47 Posted February 28, 2007 Share Posted February 28, 2007 Thanks mate, much appreciated:) its the vacuum hose style. is that the sort you need if so i can sort you out with some Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 28, 2007 Author Share Posted February 28, 2007 Not sure if that will do it, as its for my rad pipe, think i may need the reinforced type? Link to comment Share on other sites More sharing options...
Guest mk47 Posted February 28, 2007 Share Posted February 28, 2007 oh it definately will be no good for the rad mate. this is the flexible and very small round one. the diameter is probly only a few mm and i use it to replace the nasty black vacuum hoses. sorry Link to comment Share on other sites More sharing options...
