Ark Posted February 25, 2007 Share Posted February 25, 2007 Guys, I desperately need advice - I've destroyed my oil filter trying to unscrew it! The thing is on so tight that I can't move it. I used one of those bike-chain type wrenches, and it just sawed a big gash in the side of the filter... How the hell do I get the thing off to replace it? I've tried everything I can think of - three different types of wrenches from halfords were no good, I can't drive a screwdriver through it because there's no space. I tried swearing, to no avail. I can't even take it to a garage because it's now undriveable with no oil... HELP PLEASE!!! Link to comment Share on other sites More sharing options...
RedM Posted February 25, 2007 Share Posted February 25, 2007 Strap wrench? Link to comment Share on other sites More sharing options...
Ric Posted February 25, 2007 Share Posted February 25, 2007 move the PS res, room for 2 hands and get some welders gloves on should give you enough grip and protection against the sharp bits you made Link to comment Share on other sites More sharing options...
Ark Posted February 25, 2007 Author Share Posted February 25, 2007 Strap wrench? Shops are shut... move the PS res, room for 2 hands and get some welders gloves on should give you enough grip and protection against the sharp bits you made It's worth a go...but knowing my luck that'll bust the steering too... Thanks so far guys...this has to happen today...I need the car tomorrow... Link to comment Share on other sites More sharing options...
Ark Posted February 25, 2007 Author Share Posted February 25, 2007 Do you actually remove the PS res? I unbolted it, but it won't swing far enough to get out of the way...certainly not far enough to make a difference. Link to comment Share on other sites More sharing options...
Feakins Posted February 25, 2007 Share Posted February 25, 2007 Can you not get a screwdriver through it? Link to comment Share on other sites More sharing options...
Ric Posted February 25, 2007 Share Posted February 25, 2007 unbolts and it does move, the pipe bends a little bit it moves enough out of the way near the battery to let you get 2 hands down to the filter Link to comment Share on other sites More sharing options...
mr lover Posted February 25, 2007 Share Posted February 25, 2007 unbolts and it does move, the pipe bends a little bit it moves enough out of the way near the battery to let you get 2 hands down to the filter i can get both my hands on the filter then, and my forearms are big for some reason Link to comment Share on other sites More sharing options...
edge Posted February 25, 2007 Share Posted February 25, 2007 Can you not get a screwdriver through it? Link to comment Share on other sites More sharing options...
Steviekid Posted February 25, 2007 Share Posted February 25, 2007 How the hell did someone get it on so tight in the first place?! It's not the easiest thing to get at! Link to comment Share on other sites More sharing options...
Jake Posted February 25, 2007 Share Posted February 25, 2007 Undoing the bolt that holds the dipstick to the manifold and then removing the whole dipstick tube helps you get at the filter too. If necessary you can tap the rim of the filter round with a hammer and chisel just to get it started. I've had to do that a couple of times on other cars (not supras thank God) Link to comment Share on other sites More sharing options...
Chewie Posted February 25, 2007 Share Posted February 25, 2007 How the hell did someone get it on so tight in the first place?! It's not the easiest thing to get at! It's the rubber seal. It expands and pre-loads the filter case. Not on a Supe but I had break up the filter case by chain drilling and cold chiselling! Major problem was all the swarf floating about. Link to comment Share on other sites More sharing options...
Jiversteve Posted February 25, 2007 Share Posted February 25, 2007 Dont want to say stupid but.... You are trying to undo it and not tighten it. Link to comment Share on other sites More sharing options...
DannoSupra Posted February 25, 2007 Share Posted February 25, 2007 People sometimes dont grease or oil the filter seal, which causes them to be stiff or tight. Hammer and chisel/screwdriver is your best bet. Good luck mate! Link to comment Share on other sites More sharing options...
Ark Posted February 25, 2007 Author Share Posted February 25, 2007 Can you not get a screwdriver through it? I can't see an angle...certainly not with enough space to beat on it with a hammer... unbolts and it does move, the pipe bends a little bit it moves enough out of the way near the battery to let you get 2 hands down to the filter I took the battery out already, that helped. But even with two hands it wouldn't budge. Dont want to say stupid but.... You are trying to undo it and not tighten it. Anti-clockwise. I double-checked using my replacement filter. People sometimes dont grease or oil the filter seal, which causes them to be stiff or tight. Hammer and chisel/screwdriver is your best bet. Good luck mate! Ah hell I give up. I'm going to hit the beers instead before I damage something expensive in the dark. But I'm seriously pissed off, because if I can't get to work tomorrow, I can't earn money (I'm a contractor) In the morning I think I'll phone my garage and give them a piece of my mind! Link to comment Share on other sites More sharing options...
rik Posted February 25, 2007 Share Posted February 25, 2007 Have you tried shouting profanities at it, whilst stomping around destroying other nearby unrelated objects? Has been known to work sometimes! Link to comment Share on other sites More sharing options...
Rory Posted February 25, 2007 Share Posted February 25, 2007 Have you tried shouting profanities at it, whilst stomping around destroying other nearby unrelated objects? Has been known to work sometimes! lol this is what I will be doing next weekend, when I service my car! I've been used to a BMW with the easiest oil filter to change in the world - oil canister mounted at top of engine , one easy bolt, lift lid off, lift out filter. Why all cars dont have this beats me. Link to comment Share on other sites More sharing options...
supra dan Posted February 25, 2007 Share Posted February 25, 2007 i used a long scewdriver on the rim of the filter and tapped it with a hammer, you only need to move it slightly then it will come off. theres not much room but just enough Link to comment Share on other sites More sharing options...
Ark Posted February 25, 2007 Author Share Posted February 25, 2007 i used a long scewdriver on the rim of the filter and tapped it with a hammer, you only need to move it slightly then it will come off. theres not much room but just enough Ah HA! yes! I remember seeing someone do that once before...when my wheel valve covers were over tightened. I'd forgotten that trick. First thing tomorrow! Link to comment Share on other sites More sharing options...
Mike M Posted February 25, 2007 Share Posted February 25, 2007 People sometimes dont grease or oil the filter seal, which causes them to be stiff or tight. Hammer and chisel/screwdriver is your best bet. Good luck mate! Yeah, had this before with a dealership serviced car the rubber seal tries to weld itself on. Screwdriver on the rim sounds best bet to me as you could pierce a driver through the thing but what's to say that wont just twist the metal. Good luck mate, keep taking the patience pills. Link to comment Share on other sites More sharing options...
ardasaliah Posted February 25, 2007 Share Posted February 25, 2007 get some sand paper and grip is with it. GOt to have a stong hand to budge it though! Link to comment Share on other sites More sharing options...
Ark Posted February 26, 2007 Author Share Posted February 26, 2007 Thank you everyone - in the end I managed to lay my hands on a suitable filter socket wrench which did the trick. I used a 12" bar to drive it and still had to lean on it with all my weight!! Still, all's well that ends well. Link to comment Share on other sites More sharing options...
Sheefa Posted February 26, 2007 Share Posted February 26, 2007 Good man Ark. Take it you're tracking at Donington tomoz? Link to comment Share on other sites More sharing options...
Ark Posted February 26, 2007 Author Share Posted February 26, 2007 No, I've got a place on another Donny noisy day next Monday... Link to comment Share on other sites More sharing options...
Jake Posted February 26, 2007 Share Posted February 26, 2007 i used a long scewdriver on the rim of the filter and tapped it with a hammer, you only need to move it slightly then it will come off. theres not much room but just enoughAh HA! yes! I remember seeing someone do that once before...when my wheel valve covers were over tightened. I'd forgotten that trick. First thing tomorrow! I said that in Post 11 Link to comment Share on other sites More sharing options...
