Part number request
Ian C
You higlighted the NA one but thankfully the turbo one is on the second picture as well :) My bad, I wasn't specific :D
Can you look up a turbo-oil-return-to-block gasket for me as well please? I'll let you work out if that's for a turbo or not :p
-Ian
The yanks seem to think that the exhaust manifold gasket is reusable. Hmmm. I'm not convinced. OK, I've reused gaskets successfully before, but they have all been on the intake side (turbo outlets, throttle body :) etc) but I don't think I'll chance an exhaust side one...
Thanks again Jake.
-Ian
Toyota spectacularly supplied me with one of the two gaskets. So the first three cylinders have a new gasket. The gaskets are different, so it's not like I had to order two of the same part, and the screengrabs you gave me, Jake, only show one part number for the "head to manifold gasket", so it's defo their fault. I'm harassing the parts dept for a callback. A lot.
:mad:
-Ian
For future refence, there is a second part number for the second gasket. Why on earth Toyota thought splitting them up would be a good idea I don't know :mad:
T17173-46040 - Cylinders 1 to 3 exhaust manifold gasket
T17198-46010 - Cylinders 4 to 6 exhaust manifold gasket
Note hugely disparate part numbers :rolleyes: FFS
Fume rant.
-Ian
Thanks again Jake.
-Ian
My header has now been on and off about 5 or 6 times Ian and the gasket is fine , if its multi layer metal i dont see the problem re-using it .
Dude:flame Dev
Guest Terry S
Dude:flame Dev
But mate you don't see a problem re-using the HG;)
