Matt H Posted February 25, 2007 Share Posted February 25, 2007 When i have my over fenders fitted, i want to keep the same wheels, so im looking for some spacers? Any ideas? What size would i need to make the perfect fit? Ta Matt Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted February 25, 2007 Share Posted February 25, 2007 Try these guys ( http://www.srbpower.com/hr/spacers.php ) = top quality and excellent service too. I have a full set from them and they really are very good. You may need to get spigot rings as well though. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted February 25, 2007 Share Posted February 25, 2007 id buy new wheels Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted February 25, 2007 Share Posted February 25, 2007 Good idea if you happen to have a spare grand or two. If you use hub-centric spacers (within reason) then the additional stresses placed on the wheel bearings will be minimal - no more so than those created by wheels with a lesser ofset. Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 25, 2007 Author Share Posted February 25, 2007 Try these guys ( http://www.srbpower.com/hr/spacers.php ) = top quality and excellent service too. I have a full set from them and they really are very good. You may need to get spigot rings as well though. i went to the bottom of the page and there was like 100's of options! Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 25, 2007 Author Share Posted February 25, 2007 If you use hub-centric spacers (within reason) then the additional stresses placed on the wheel bearings will be minimal - no more so than those created by wheels with a lesser ofset. Sounds good. So if i said to Turbofit, when they are doing my intercooler, sort us out with appropriate hub centric spacers would that be enough for the job to be done? Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted February 25, 2007 Share Posted February 25, 2007 LOL - there are a few options. It's easier if you know first of all how wide you wanna go. Give em a ring if in doubt - they are very helpful. Anything more than 5mm per side and you're gonna need longer studs too! Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 25, 2007 Author Share Posted February 25, 2007 LOL - there are a few options. It's easier if you know first of all how wide you wanna go. Give em a ring if in doubt - they are very helpful. Anything more than 5mm per side and you're gonna need longer studs too! Well i always thought i would need a spacer the same width as the over fenders... but thats probably pretty wide. argh i dont know!! lol Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted February 25, 2007 Share Posted February 25, 2007 I can get hubcentric spacers. 10, 15, 20, 25mm I think. Not my personal choice but I can sell them. Price is around £70+ for a pair. Gaz. Quote Link to comment Share on other sites More sharing options...
TLicense Posted February 25, 2007 Share Posted February 25, 2007 Although it's quite a different set-up, F1 cars use wheel spacers pretty much all the time. Depending on the suspension set-up for a circuit, the wheel track (distance between LH and RH wheels) changes. We then use spacers to move it back out to the max legality. Quote Link to comment Share on other sites More sharing options...
charlton Posted February 25, 2007 Share Posted February 25, 2007 I've got Veilside arches and spacers, i think mine are around 1 inch or just under and it fills them nicely - let me know if you want me to check 100% for sure Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 25, 2007 Author Share Posted February 25, 2007 I've got Veilside arches and spacers, i think mine are around 1 inch or just under and it fills them nicely - let me know if you want me to check 100% for sure that would be great cheers! Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted February 25, 2007 Share Posted February 25, 2007 I've got Veilside arches and spacers, i think mine are around 1 inch or just under and it fills them nicely - let me know if you want me to check 100% for sure Obviously you'll need to compare the actual ofsets of the two different sets of wheels too Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 25, 2007 Author Share Posted February 25, 2007 Obviously you'll need to compare the actual ofsets of the two different sets of wheels too monge tu Rodney! Quote Link to comment Share on other sites More sharing options...
charlton Posted February 28, 2007 Share Posted February 28, 2007 Sorry for the late reply, I forgot to check!! My spacers are 2cm and my wheels are 265 on the rear - I'm not sure what the offset is but it doesn't look like much 1-2cm maximum. On the front I do not have spacers Let me know if you need anything else Quote Link to comment Share on other sites More sharing options...
leonv Posted March 1, 2007 Share Posted March 1, 2007 Sounds good. So if i said to Turbofit, when they are doing my intercooler, sort us out with appropriate hub centric spacers would that be enough for the job to be done? Is this the first time you will be using Turbo-fit Matt Quote Link to comment Share on other sites More sharing options...
Matt H Posted March 1, 2007 Author Share Posted March 1, 2007 Is this the first time you will be using Turbo-fit Matt yeah it will be Quote Link to comment Share on other sites More sharing options...
leonv Posted March 2, 2007 Share Posted March 2, 2007 yeah it will be You will find it a positive experience Quote Link to comment Share on other sites More sharing options...
garethr Posted March 2, 2007 Share Posted March 2, 2007 If you must use spacers, make sure that they are hub-centric and TUV-approved. Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted March 2, 2007 Share Posted March 2, 2007 Like these http://www.mkivsupra.net/vbb/showthread.php?t=101531 :) Quote Link to comment Share on other sites More sharing options...
