2JZ-GTE-IS200 Posted February 25, 2007 Share Posted February 25, 2007 im fitting a Autometer tacho to the race car, i have the tacho adapter, but i need to find the primary power feed to the coils, before it splits to power each coil. i dont need the ecu pins as i am not running with the oem ecu, and the HKS FCON v Pro doesnt have a tacho out any help would be very much appreciated. to confirm all i need it the power wire for the coil packs before it splits to feed each individual coil pack mat Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted February 25, 2007 Author Share Posted February 25, 2007 if no one knows does anyone have the wire diagram for the coils then please Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted February 25, 2007 Author Share Posted February 25, 2007 ? no one Link to comment Share on other sites More sharing options...
TLicense Posted February 25, 2007 Share Posted February 25, 2007 There's an entire electrical manual on here:- http://www.mkiv.com/manual/index.html Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted February 25, 2007 Author Share Posted February 25, 2007 Tony, thanks but i dont seem to find the coil and igniter circuits on there edit: found some info that ive sent to a pal in canada whois a supra expert, will let everyone know when i find out for future reference Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted March 5, 2007 Author Share Posted March 5, 2007 black/orange at the igniter pack Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted April 10, 2007 Author Share Posted April 10, 2007 update, the wire at the igniter doesnt work. i ended up using the coil feeds...works a treat, now i can see what RPM the engine is doing Link to comment Share on other sites More sharing options...
JustGav Posted April 10, 2007 Share Posted April 10, 2007 Why didn't you just use one of the RPM signal wires at the ECU side of things? Sorry. just read that you didn't use the stock ECU... never mind I'll go back to sleep Link to comment Share on other sites More sharing options...
Wez Posted April 10, 2007 Share Posted April 10, 2007 Doesnt the FCON Pro V plug into the stock loom so the pinout would be the same? Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted April 11, 2007 Author Share Posted April 11, 2007 the fcon v pro in mine is spliced into the is200 ecu loom The car is not a Supra the ecu output is 5v square wave, the aftermarket tachometers need to see 12v the adaptor senses voltage drop and converts the pulse to a readable signal at the tachometer. hence why i took the feed from the 12v ign feed to the coils in the end. Link to comment Share on other sites More sharing options...
gsportcars Posted April 11, 2007 Share Posted April 11, 2007 Hi Mat, As far as I could tell the ignition live in the supra is a constant live and the coils are triggered through earth. Just wondering how you could get a feed for a tacho from a constant live??? Or am I talking through my derrier? Anyway at least you got it sorted. Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted April 11, 2007 Author Share Posted April 11, 2007 nope the feed for the coils is defiantly switched 12v Link to comment Share on other sites More sharing options...
dandan Posted April 11, 2007 Share Posted April 11, 2007 Only just spotted this thread and I may have been able to help by pointing you here.... http://supraforums.com/forum/showthread.php?t=274118 Could you have used the green tach wire from the ignitor or has that already been conditioned to 5v? Link to comment Share on other sites More sharing options...
2JZ-GTE-IS200 Posted April 11, 2007 Author Share Posted April 11, 2007 yep, the tach signal is 5v Sq wave Link to comment Share on other sites More sharing options...
