Aluminium Speedo Rings
chilly
I have some, and yes they are nice, alot better looking aesthetically than black plastic (or white in your case Chilly) :)
They're pretty pricey for what they are though, Im pretty sure they're around the £40 mark.
You could alternatively mask up your dash panel and use some chrome effect spray and spray the plastic rings around the dials...bit of an arse though I'd imagine.
Edit:
Or you could ask Jezzybabes if any Supra's in his breakers have any in them.
http://mooch.pwp.blueyonder.co.uk/supra/dash.jpg
....bit blurry but you get the gist.
Edit:
[qimg]http://mooch.pwp.blueyonder.co.uk/supra/dash.jpg[/qimg]
i have asked jezzy to keep a look out
These are difficult to remove with out damage. They are coated plastic. I believe the were standard fit on the wood effect dash The coating is very thin and easy to partially remover with a little zealous polishing. You are much better off buying new. JMHO
I got mine from Nic, as the previous owner had been to rough with cleaning and removed part of the chrome finish.
