uzthedentist Posted February 24, 2007 Share Posted February 24, 2007 My supra speedo only goes up to 110 mph. Id like to change the faces anyway to thor stainless type but would i have to change the whole clock to make it read up to 180 or is there a way to adjust it? Link to comment Share on other sites More sharing options...
markjodrell Posted February 24, 2007 Share Posted February 24, 2007 the original jap clock would have read 180kph, the quick ay way of converting the dial is to put 112mph dial on instead , 180kmh=110mph If you want 180 you will haqve to have the odometer chipped, this will also de restrict it Link to comment Share on other sites More sharing options...
carl0s Posted February 24, 2007 Share Posted February 24, 2007 Yup, the normal fix is to have a speedo-convertor fitted, which makes 30mph display as 30kmh on the dial, then you have a little MPH sticker which goes over the KM/H on the dial face. That way your speedo reads up to 180MPH. De-limiter is a separate thing altogether though, except that Thor offer a combined de-limiter and speedo convertor unit. Link to comment Share on other sites More sharing options...
Adam Posted February 24, 2007 Share Posted February 24, 2007 Mine still says 110 max out but bought an rsm (revs speed meter) which de limited it and it just falls past it and keeps going i always look at the road angel for an accurate reading. Link to comment Share on other sites More sharing options...
