Whats my gearbox?
madmunky
I have a Auto TT J-spec and am slowing trying to work out what been modified, I know the ecu has been changed and its got FMIC but one of the things is the gearbox, I dont have a Drive option only "L" and "2" when you select "2" it lights up Drive on the dash, anyone know what this is all about?
car drives fine btw :)
Well, if its working correctly, you'll only have 2 forward speeds. AFAIK the GM Powerglide 'box is the only one around like that these days.
They tend to stick them in drag cars so you don't lose time changing gear over the 1/4.
If it is one, its not a bad 'box, but you need to optimise the axle ratio to get it to max out just as you cross the line.
