SupraStar 3000 Posted July 10, 2004 Share Posted July 10, 2004 Just pre-anticipating any problems I may having fitting a: BLITZ - NUR SPEC S EXHAUST to my: Mk4 SUPRA (IMPORT) - NA / AUTO. With no free weekends until JAE and very little time in the evenings I hope the exhaust will bolt straight on. I'll receive the unit from Paul Whiffin next week and have already prepared the car. Anything I need to know in advance or advice? Never done an exhaust transplant before Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted July 10, 2004 Share Posted July 10, 2004 wasnt there talk awhile ago saying bigger 3"+ exhausts were not good tor N/A cars something along the lines of you need back pressure? think it was in MIAMI RICE section Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 10, 2004 Share Posted July 10, 2004 Faye has an NA Auto and the blitz fitted on hers and that runs fine. I think the back pressure issue comes from 3" cat replacement pipes and the complete 'freeing up' of the exhaust. Not sure what you mean by 'prepared the car' does this mean you've removed the stock pipe? Possible problem could be the rear hanger, i suspect you may get the rubber attachments etc with the Blitz but i don't know and if not it could cause you hassle. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted July 10, 2004 Share Posted July 10, 2004 I have a HKS hyper with 3 inch piping on my N/A and its only really noticeable effect is mucho loudness:D I got my local garage bloke to change it for me on the ramps for a heady tenner. The biggest problem I think you will have is getting the bolts undone. Exhaust bolts can be a tad of an ass to undo especially if you are doing the job on jacks/axle stands. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 10, 2004 Author Share Posted July 10, 2004 Thanks people What i meant by 'prepared the car' was loosening the bolts, jacks/axle stands and sitting down with the car and explaining to it the benefits of the mod and procedure of the operation I was just alittle apprehensive about doing the work myself but things should go smoothly..........i hope Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 10, 2004 Share Posted July 10, 2004 Originally posted by SupraStar 3000 Thanks people What i meant by 'prepared the car' was loosening the bolts, jacks/axle stands and sitting down with the car and explaining to it the benefits of the mod and procedure of the operation I was just alittle apprehensive about doing the work myself but things should go smoothly..........i hope Sounds like you'll be fine. I think most aftermarket pipes use the same rubber hanger that the stock centre section (passenger side silencer) does, and locating the nur in that rubber and attaching the 2 bolts you've loosened will fully support the exhaust enough for you to sort out the final rear most hanger.... My old blitz back box has an L-shaped up and across hanger (ie bumper to bumper, not front to back) that makes it IMO a little difficult. Mine was secondhand, so i'd hope you will get something to make this easier........maybe someone who's brought a new one could confirm this for you................ BTW i'm glad you've talked it through with the car, so many people would have missed this vital step:) Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 10, 2004 Author Share Posted July 10, 2004 Cheers Scooter appreciate all your help. I'll post my results after the jobs done! Quote Link to comment Share on other sites More sharing options...
