Club Competition #2
mawby
  • Replies 1.6k
Posted Images
Estimates are that 80 percent of all nasal septums are off-center, a condition that is generally not noticed. A "deviated septum" occurs when the septum is severely shifted away from the midline. The most common symptom from a badly deviated or crooked septum is difficulty breathing through the nose. The symptoms are usually worse on one side, and sometimes actually occur on the side opposite the bend. In some cases the crooked septum can interfere with the drainage of the sinuses, resulting in repeated sinus infections.
Wow! I suffer terrible with my sinus's (sp?), I know drinking and smoking doesn't help :( but that might be the reason.
I know I should go and see a doctor for advice but do you know if it can be treated Dr Michael?
The Main Library at Indiana University sinks over an inch every year because when it was built, engineers failed to take into account the weight of all the books that would occupy the building.
They should fill the attic with a load of helium ballons.. problem solved :innocent:
Is that really true?? If it is, its funny, but amazing too!
I went to the docs with a mildly deviated septum last week, it can be treated or helped with sprays but the only proper fix is to hack away with sharp objects, fill your nose with sewn in plastic supports and then pack it with cotton wool... I opted for the spray :)
Google "Septoplasty"
An example:
Septoplasty is a surgical procedure performed entirely through the nostrils, accordingly, no bruising or external signs occur. The surgery might be combined with a rhinoplasty, in which case the external appearance of the nose is altered and swelling/bruising of the face is evident. Septoplasty may also be combined with sinus surgery.
The time required for the operation averages about one to one and a half hours, depending on the deviation. It can be done with a local or a general anesthetic, and is usually done on an outpatient basis. After the surgery, nasal packing is inserted to prevent excessive postoperative bleeding. During the surgery, badly deviated portions of the septum may be removed entirely, or they may be readjusted and reinserted into the nose.
If a deviated nasal septum is the sole cause for your chronic sinusitis, relief from this severe disorder will be achieved.
And if you haven't eaten yet click this:
http://images.google.co.uk/images?hl=en&q=Septoplasty&btnG=Search+Images&gbv=2
Gorillas are the largest living primates - the family of animals that includes monkeys, apes and humans. A mature male gorilla can be over 6 feet tall and weigh 300 to 500 pounds. He can spread his arms 8 feet across and is as strong as 4 to 8 strong men. Adult female gorillas are about half the size of the males.
in the 1500's
Baths consisted of a big tub filled with hot water. The man of the house had the privilege of the nice clean water, then all the other sons and men, then the women and finally the children. Last of all the babies. By then the water was so dirty you could actually lose someone in it. Hence the saying, Don't throw the baby out with the Bath water..
There was a guy riding through the desert on his camel. He had been travelling so long that he felt the need to have sex. Obviously there were no women in the desert so the man turned to his camel.
He tried to position himself to have sex with his camel but the camel ran away. The man ran to catch up to the camel and got back on and started to ride again. Soon he was feeling the urge to have sex again so once again he turned to his camel. The camel refused by running away. So he caught up to it again and got on it again.
Finally after riding the camel through the whole desert the man came to a road. There was a broken down car with three big chested beautiful blondes sitting in it.
He went up to them and asked the women if they needed any help.
The hottest girl said , "If you fix our car we will do anything you want."
The man luckily knew a thing or two about cars and fixed it in a flash.
When he finished are three girls asked, "How could we ever repay you Mr."
After thinking for a short while he replied, "Could you hold my camel?"
This topic is now closed to further replies.
