big box small box
Supra ST Myster
Funny enough I keep getting that, the only quick fix I have found is that when you open the window, drag a corner to make it as big as possible , then it should open like that next time
:yeahthat: it happens to me sometimes. very annoying!
If you maximise an IE window it will always open at the size you had it at last in normal mode.
You need to drag the corners of the window to where you want them, then exit IE. Make sure it's the only IE window open first though. If you have another open then its settings will be remembered instead.
