HELP! - Heat, smoke & bad noise!
Grazer
Just got the pressure test done which nicely demonstrated water/coolant pissing out of the water pump at an alarming rate :thumbs:
If you'd told me a few days ago my water pump was going to break I would have been pissed off, but compared to other possiblities it's a relief!
I bet!
I know how relieved you must be, I was similarly happy when I found out my rad had cracked.
As you say, you've had a result there mate, could've been much worse.
Mind you, changing the water pump doesn't look like a walk in the park either from what I could see when i was thinking of changing my stat.
The guy in the local garage said he'd fit it for about £60 - sounds reasonable to me. I'm still not sure which bit is the water pump :eek: :p
Am I right in thinking the pump is about £60?
£60! Blimey I wouldn't want to do it for £60.
Buy a cambelt and get him to shove that on at the same time cause he has to take it off to do the pump and dont forget to buy the O ring that goes between the housing and the block behind the pump !!!! :sly:
Dude:flame Dev
sorry.. my stupidity.
There was a thread on here yesterday where the pound sign didn't display properly among other things, because it was posted using UTF-8 encoding but the page didn't specify it.
When I read this thread the "£60" looked like a funny triangle but it turns out I had set my browser for Chinese Simplified when I was messing yesterday :-)
Cambelt replaced last year. I take it this O ring wont come with the pump then? Where would I get it - toyota?
  • 3 weeks later...
Well that's me sorted:
Water pump £120.00 approx
Timing belt £28.30
Labour £401.25
Total £564.50 :eek:
Oh well, I suppose it's worth it! They charged for 10hours labour as this gave the price that Toyota had quoted - although they said it took them about 16hours.
If anything else goes wrong this year I may have to say bye bye :eek:
Timing belt £28.30
Labour £401.25
Total £564.50 :eek:
£400 labour??? I had a cambelt done with a full service and brake pads replaced on the front for £360 all in. That water pump must be a right git to take off:(
Plus if you have spent that much cash on it recently you will have to protect ur investment with a bit more lol. Thats the theory i used on me busted Omega
