Raising my boost - RR and BC
Sheefa
OK, I have, I believe a RR fitted, not sure what size and of course an on dash Boost Controller which I believe is a Blitz SB-II or something like that! The same as Hecklers and you can get a Power Meter for it too which looks pretty much the same.
I've raised the boost, correctly I hope, to 1.2 Bar, but I never seem to see more than 0.76 on A) the boost controller reading itself and B) the mechnical greddy boost gauge I have fitted.:search:
Chris Wilson has tested everything and given the A-OK for fuelling etc, good mix - not lean or rich.:D
I just wondered, do you only creep above 1bar, or 0.8 in my case when you hit a) silly speeds, or b) a higher rev limit near to the redline in a lower gear?
I want to know that I can 'push' the car to the 1.2 bar level safely and it actually works.
I also have Envy Hybrids fitted, but stock J-spec 440's.
Any advice guys? I'm not sure if I'm configuring the BC correctly! :)
Cheers,
Greg
