Overdrive button
Guest DMo
Hi,
I'm after an overdrive button. The wires are there so just need the button. If the wires are attached, that's not a problem. As long as it's all intact and can be mounted back in the auto stick.
Thanks,
D.
Is it in good condition? How much would you like for it including postage?
I'm not desperate. Everythings running fine without it, but obviously can't toggle between modes.
Thanks,
D.
It works fine and if memory serves me correctly it is in good condition. Mine was modified to work as a lock up switch for my torque converter and a new o/d switch was placed where the ashtray was. It was just the wiring that was fiddled with though, the switch works fine. I have since gone manual so the whole set-up is sitting in my garage.
I would need to remove it, I assume it is easy enough to do though.
Just give me enough to cover the postage and I'll get it to you a.s.a.p.
Joe
