Guru Posted February 21, 2007 Share Posted February 21, 2007 What is the bottle on the drivers side behind the orange indicator in the duct? The car is in the garage so I can't see what it's for Link to comment Share on other sites More sharing options...
Homer Posted February 21, 2007 Share Posted February 21, 2007 Edit - erm, got the left and right confused. Not sure mine has anything on the drivers side! Thats there the SMIC normally sits. Link to comment Share on other sites More sharing options...
merckx Posted February 21, 2007 Share Posted February 21, 2007 Thats the washer fluid bottle - its enormous. I haven't got one on the drivers side, mine's on the left. Link to comment Share on other sites More sharing options...
Homer Posted February 21, 2007 Share Posted February 21, 2007 I haven't got one on the drivers side, mine's on the left. Stop pointing out that I can't tell left from right Link to comment Share on other sites More sharing options...
merckx Posted February 21, 2007 Share Posted February 21, 2007 Stop pointing out that I can't tell left from right I think Guru can't either! Link to comment Share on other sites More sharing options...
Guru Posted February 21, 2007 Author Share Posted February 21, 2007 No it's definitely the drivers side! I thought the SMIC would be but I have a FMIC anyways..... Strangely I can't remember the last time I filled up the washer fluid and my Polo has it on the passenger side so am confused. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 21, 2007 Share Posted February 21, 2007 It's probably the radiator coolant expansion tank, which will have ben moved to fit the FMIC. Link to comment Share on other sites More sharing options...
garetheves Posted February 21, 2007 Share Posted February 21, 2007 It's probably the radiator coolant expansion tank, which will have ben moved to fit the FMIC. Link to comment Share on other sites More sharing options...
Guru Posted February 22, 2007 Author Share Posted February 22, 2007 I will check for custom fitting then and see what level its at if any I guess if it's empty thats ok then? Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 22, 2007 Share Posted February 22, 2007 I will check for custom fitting then and see what level its at if any I guess if it's empty thats ok then? No, it should be about 1/3 full of coolant mix. Link to comment Share on other sites More sharing options...
mplavery Posted February 22, 2007 Share Posted February 22, 2007 just a guess...its not thr dryer unit for the air con ??? Link to comment Share on other sites More sharing options...
Guru Posted February 22, 2007 Author Share Posted February 22, 2007 No, it should be about 1/3 full of coolant mix. Ok will investigate further and get photos of the mythical bottle Link to comment Share on other sites More sharing options...
Sheefa Posted February 22, 2007 Share Posted February 22, 2007 That clears that up! Mine was empty but I've topped it up now. However, mine is located by the battery feeding into the Rad cap. Link to comment Share on other sites More sharing options...
Guru Posted February 24, 2007 Author Share Posted February 24, 2007 Looks like mystery sold as it is the relocated expansion bolt. My Wilson wins the pride of knowing it Link to comment Share on other sites More sharing options...
rik Posted February 24, 2007 Share Posted February 24, 2007 Where do the pipes run too/from this bottle? I've been building up the front end of my car today, and can't find the pipes for the expansion bottle Saying that, i couldn't find the bottle but i;m sure it's in one of the sheds! Does one come from the rad fill neck? Link to comment Share on other sites More sharing options...
Guru Posted February 24, 2007 Author Share Posted February 24, 2007 Yep one comes off the rad to the right of the cap. The other is an overflow pipe ..... Link to comment Share on other sites More sharing options...
rik Posted February 24, 2007 Share Posted February 24, 2007 Ah cool. Hopefully when i find my bottle it will have the pipes on it. CW mentioned earlier that it has to be 3/4 full, why is this? Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 25, 2007 Share Posted February 25, 2007 The cooling system vents and sucks to and from this reservoir as it heats up and cools down. Link to comment Share on other sites More sharing options...
rik Posted February 26, 2007 Share Posted February 26, 2007 Ah, i see. Link to comment Share on other sites More sharing options...
