A very proud owner!
Guest SUPRA-TURBO
Guest SUPRA-TURBO
All right then apexi seals, stage 4 turbo custom made intercooler, blitz dump valve, forged pistons, ecu chip, light weight works wheels, blitz exhaust, lsd box, fully custom made extra gear, racing fly wheel, 150 shots of noz, toyo tyres, after market manifold came with the car, engine balancing, port polish.
  • Replies 169
How about this spec, Googled in seconds :p
3S-GT 2.2L 618hp [full boost 1.8km/cm (25.6psi)] / Ported Bored cylinders/ Custom Camshaft (IN:272-11.5mm EX:280-11.5mm) / Valve springs for high lift / Titanium Retainers / Valve Lifters / HKS Head Gasket(1.2mm) / Custom Forged Pistons (87mm) / H-beam Connecting Rods / Custom Crankshaft for 5F / HKS T04 / Apexi Racing Wastegate / Custom Exhaust Manifold(48.6mm) / Custom Exhaust System ( Mid-section: 80mm Tail-section: 115mm*2) / HKS Power Flow Intake / Custom Intercooler (fit in the trunk) / Intake Piping (IN:80mm / OUT:90mm) / Infiniti 90mm Throttle Body / 16 plate Oil Cooler / Bosch Fuel Pump x2 / HKS Fuel Rail / SaRD Fuel Pressure Regulator / Blitz Injectors 1000cc x4 / NGK IRIWAY #8 / Apexi Power FC / Custom C-type Twin-Plate Clutch / 5-speed Cross Geared Transmission / Shift Cable / TRD LSD / Custom 4.5 final gear
