merckx Posted February 19, 2007 Share Posted February 19, 2007 Where's everyone going to get their 12V supply from? In the manual it says it consumes 1.3 Amps but it recommends using a 10 Amp fuse , I'm thinking the sensor might consume more than 1.3 while it's reaching working temp. Obviously it has to be an ignition swiched supply. I don't really want to connect a 10A fused item to an existing circuit that's going to be possibly overloaded . Quote Link to comment Share on other sites More sharing options...
heckler Posted February 19, 2007 Share Posted February 19, 2007 i just connected mine to the headunit suppy... Quote Link to comment Share on other sites More sharing options...
Jake Posted February 19, 2007 Share Posted February 19, 2007 I used the Odometer feed Quote Link to comment Share on other sites More sharing options...
TrickTT Posted February 19, 2007 Share Posted February 19, 2007 I've run a seperate 25 amp supply off the back of the ignition switch for all the aftermarket electrics. I just routed a cable round the dash and ecu area and back to the ignition switch in a ring main configuration, and i can just spur off with an individual fuse for all the bits i have - RLTC / AEM wb02 /avcr / gauges / edfc etc Quote Link to comment Share on other sites More sharing options...
merckx Posted February 19, 2007 Author Share Posted February 19, 2007 I've run a seperate 25 amp supply off the back of the ignition switch for all the aftermarket electrics I wasn't sure if the direct ignition supply would have much spare capacity. I was thinking about an independent supply direct from the battery and swiching it with a relay using an ignition feed, I could also use this for all my extra devices in the car. Quote Link to comment Share on other sites More sharing options...
merckx Posted February 19, 2007 Author Share Posted February 19, 2007 i just connected mine to the headunit suppy... That's what I normally use, just didn't fancy having too much connected to the same place. Quote Link to comment Share on other sites More sharing options...
Angarak Posted February 19, 2007 Share Posted February 19, 2007 I was under the impression the head unit supply wasnt on a 10amp circuit. I used the Odo loom for mine which is a 10amp circuit. Quote Link to comment Share on other sites More sharing options...
