paul_y3k Posted February 18, 2007 Share Posted February 18, 2007 wwhilst investigating a rattle comnig from the passenger side of the engine bay, I found the the FPR was lose on it's brakets, I've tightened it up, but whilst doing so my fingers became a little damp. Had a sniff and it's defo pertol, am I ok to give the fittings a good tighten, or do i need to be careful here so's not to snap anything / over tighten ? and yep it goes without saying i shant be smoking or using a naked flame to illuminae what I'm doing. Link to comment Share on other sites More sharing options...
uk-rich Posted February 18, 2007 Share Posted February 18, 2007 i'd try nipping up the unions, do not over tighten as you will strip the threads Link to comment Share on other sites More sharing options...
Jake Posted February 18, 2007 Share Posted February 18, 2007 Paul, I've got a spare stock FPR if you need it mate Link to comment Share on other sites More sharing options...
paul_y3k Posted February 18, 2007 Author Share Posted February 18, 2007 cheers Jake .. might need to take you up on that - Will see what happens with this one. But would a stock one cope with a single turbo setup ? *edit* aaggh just discovered my baattery clamp has rusted away at the bottom of the pole ! Link to comment Share on other sites More sharing options...
Jake Posted February 18, 2007 Share Posted February 18, 2007 But would a stock one cope with a single turbo setup ? I guess if it's running stock fuel pressure it'll be fine. Is it not the stock one you're having a problem with then? Link to comment Share on other sites More sharing options...
paul_y3k Posted February 18, 2007 Author Share Posted February 18, 2007 naah aeromotive jobby. Link to comment Share on other sites More sharing options...
bondango Posted February 18, 2007 Share Posted February 18, 2007 wwhilst investigating a rattle comnig from the passenger side of the engine bay, I found the the FPR was lose on it's brakets, I've tightened it up, but whilst doing so my fingers became a little damp. Had a sniff and it's defo pertol, am I ok to give the fittings a good tighten, or do i need to be careful here so's not to snap anything / over tighten ? and yep it goes without saying i shant be smoking or using a naked flame to illuminae what I'm doing. If its an aeromotive as you say, then i would suggest using some PTFE paste (pipe dope) on the AN fittings. Link to comment Share on other sites More sharing options...
paul_y3k Posted February 18, 2007 Author Share Posted February 18, 2007 will that not risk contaminating the fuel though ? Link to comment Share on other sites More sharing options...
bondango Posted February 18, 2007 Share Posted February 18, 2007 as long as its a good PTFE based one it will be fine, i prefer it over the tape and it will stop the fittings becoming loose through vibration. Link to comment Share on other sites More sharing options...
