boromfccup Posted February 17, 2007 Share Posted February 17, 2007 erratiic idle after going bpu any answers please Quote Link to comment Share on other sites More sharing options...
Ric Posted February 17, 2007 Share Posted February 17, 2007 since going BPU or since fitting a thor fcd? Quote Link to comment Share on other sites More sharing options...
Homer Posted February 17, 2007 Share Posted February 17, 2007 Also, have you reset the ECU since the mods? Quote Link to comment Share on other sites More sharing options...
lambertpig Posted February 17, 2007 Share Posted February 17, 2007 possibly your foot trembling on the pedal after a run;) Quote Link to comment Share on other sites More sharing options...
boromfccup Posted February 17, 2007 Author Share Posted February 17, 2007 ive not reset the ecu, how and should i do this Quote Link to comment Share on other sites More sharing options...
jayssupra Posted February 17, 2007 Share Posted February 17, 2007 Got your car back then Quote Link to comment Share on other sites More sharing options...
boromfccup Posted February 17, 2007 Author Share Posted February 17, 2007 not yet can you phone me Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted February 17, 2007 Share Posted February 17, 2007 ive not reset the ecu, how and should i do this Disconnect the battery mate and then go for a cuppa. Reconnect when you're supping the tea leaves - that's it; easy!!. ................and then go for a drive Quote Link to comment Share on other sites More sharing options...
boromfccup Posted February 17, 2007 Author Share Posted February 17, 2007 will that cure bad idle,and cant boost to 1.2 bar with the profec b ebc Quote Link to comment Share on other sites More sharing options...
imi Posted February 17, 2007 Share Posted February 17, 2007 will that cure bad idle,and cant boost to 1.2 bar with the profec b ebc maybe or maybe not - but certainly worth a try. Quote Link to comment Share on other sites More sharing options...
Homer Posted February 17, 2007 Share Posted February 17, 2007 will that cure bad idle,and cant boost to 1.2 bar with the profec b ebc After you reset it, take it out for a reasonably steady drive including some After 15-20mins it should setle down to a steady idle, if not then you have an issue Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted February 19, 2007 Share Posted February 19, 2007 I have exactly the same, but in the BPU process I changed plugs, which is not all that good at idle for some reason. Maybe you have come across the same thing? If you didn't do it yourself, maybe your mechanic took the easy way out and changed the plug "distance" (measure on the plug itself) a bit to quickly? I think that is what happed with me. But as long as its just at idle, it just make your car sound more angry Quote Link to comment Share on other sites More sharing options...
