Max Headroom Posted February 16, 2007 Share Posted February 16, 2007 Loads very quickly, and looks very good. I only have one observation. On the photos you have the date stamp, it would probably be better if they weren't their as they would date the website very quickly Quote Link to comment Share on other sites More sharing options...
Jive Posted February 16, 2007 Share Posted February 16, 2007 Bah .. the websites not working for me Quote Link to comment Share on other sites More sharing options...
merckx Posted February 16, 2007 Share Posted February 16, 2007 Not working for me either. Quote Link to comment Share on other sites More sharing options...
peter richards Posted February 16, 2007 Author Share Posted February 16, 2007 down for me atm , pete there is a reference to machine polishing , but its in its infancy atm , theres a big difference between polishing and actual paint restoration , which im in the process of sorting takes time and practice , so i dont mind atm if its low key on the site Quote Link to comment Share on other sites More sharing options...
SupraStormRising Posted February 16, 2007 Share Posted February 16, 2007 Down for me to seems to be a DNS issue is your host down? I always advise people to have at least two DNS servers preferably in two different global locations...! Quote Link to comment Share on other sites More sharing options...
Lewis Posted February 16, 2007 Share Posted February 16, 2007 Category Status Test Name Information Parent PASS Missing Direct Parent check OK. Your direct parent zone exists, which is good. Some domains (usually third or fourth level domains, such as example.co.us) do not have a direct parent zone ('co.us' in this example), which is legal but can cause confusion. INFO NS records at parent servers Your NS records at the parent servers are: ns167.websitewelcome.com. [NO GLUE; No A record] ns168.websitewelcome.com. [NO GLUE; No A record] [These were obtained from ns4.nic.uk] PASS Parent nameservers have your nameservers listed OK. When someone uses DNS to look up your domain, the first step (if it doesn't already know about your domain) is to go to the parent servers. If you aren't listed there, you can't be found. But you are listed there. WARN Glue at parent nameservers WARNING. The parent servers (I checked with ns4.nic.uk.) are not providing glue for all your nameservers. This means that they are supplying the NS records (host.example.com), but not supplying the A records (192.0.2.53), which can cause slightly slower connections, and may cause incompatibilities with some non-RFC-compliant programs. This is perfectly acceptable behavior per the RFCs. This will usually occur if your DNS servers are not in the same TLD as your domain (for example, a DNS server of "ns1.example.org" for the domain "example.com"). In this case, you can speed up the connections slightly by having NS records that are in the same TLD as your domain. FAIL DNS servers have A records ERROR. One or more of your DNS servers are missing A records (per NS records that may be cached). As a result, they cannot be used. The problem hostnames are: ns167.websitewelcome.com. has no A record. ns168.websitewelcome.com. has no A record. NS FAIL NS A timeout occurred getting the NS records from your nameservers! None of your nameservers responded fast enough. They are probably down or unreachable. I can't continue since your nameservers aren't responding. If you have a Watchguard Firebox, it's due to a bug in their DNS Proxy, which must be disabled (31 Jul 2006 UPDATE: several years after being informed of this, there is a rumor that there is a fix that allows the Watchguard DNS proxy to work). Quote Link to comment Share on other sites More sharing options...
Ric Posted February 16, 2007 Share Posted February 16, 2007 Lol the meta tags i just copy from site to site, so hence why it has some stuff before. It isnt a template either lol i made it in photoshop same with all the sites. The gallery opens in another window because it doesn't fit correctly into the site, plus its based on simpleviewer Forwarded that to the hoster lewis as im not 100% what it all means. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted February 16, 2007 Share Posted February 16, 2007 Website looks real good Peter. Best of luck Quote Link to comment Share on other sites More sharing options...
Angarak Posted February 17, 2007 Share Posted February 17, 2007 Visually the site looks great Peter. Nice graphics Carbonangel Quote Link to comment Share on other sites More sharing options...
Lewis Posted February 17, 2007 Share Posted February 17, 2007 Ric, It's saying that the nameservers were not setup correctly (they may have been down). I believe you on the design front (not that it matters). I just recognise the design, saying that, a lot of designs look similar even when they are custom. It might just be the arse end of the car I don't know. Congrats on the site, looks good as I said before. Lewis Quote Link to comment Share on other sites More sharing options...
Ric Posted February 17, 2007 Share Posted February 17, 2007 yeah i forwarded it too the hoster, he was upgrading yesturday morning so there was a slight outage, should be k now, glad you like it. Quote Link to comment Share on other sites More sharing options...
Pete Posted February 17, 2007 Share Posted February 17, 2007 It's saying that the nameservers were not setup correctly (they may have been down). You can't talk about name servers! Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted February 17, 2007 Share Posted February 17, 2007 Good job Quote Link to comment Share on other sites More sharing options...
Ewen Posted February 17, 2007 Share Posted February 17, 2007 Looks great Peter. Shame you are so far away, I'd definately use and abuse you. Quote Link to comment Share on other sites More sharing options...
peter richards Posted February 17, 2007 Author Share Posted February 17, 2007 thanks guys for the kind and positive comments , i think im living in the wrong part of the country . thanks again to ric for putting all together for me Quote Link to comment Share on other sites More sharing options...
Lewis Posted February 17, 2007 Share Posted February 17, 2007 You can't talk about name servers! oh you bitch! At least my websites still worked Quote Link to comment Share on other sites More sharing options...
