My Supra Single project
johnd-mkiv
After a year of saying no I wont mod the supra I have given in :) been collecting parts over the past few weeks to aid my project. I am going for a full engine rebuild with a single turbo install it will have the following spec
BL T67 single turbo
XS power 50mm wastegate
XS power manifold
XS power, down pipe, induction pipe, screamer pipe
XS power, front mount intercooler
Miami gt oil feed and return lines
AEM air filter
Turbo blanket
I will be making a 1 off custom 3" custom stainless exhaust system, from the turbo back
JE 86.50mm pistons
Eagle 4340 Steel H Beam rods with ARP bolts
ARP head bolts and mains
New Oem, oil pump and water pump
Greedy timing belt
Crower Ti springs and retainers
HKS head gasket
HKS 264" EX & IN cams
HKS cam wheels
Koyo rad
Excedy twin plate clutch
HKS fuel rail with precision 880cc injectors
Walbro fuel pump
Aem engine management
HKS dli 2
AEM wide band
Apexi el series 2 60mm gauges - Boost, EGT, Water temp, Oil temp, Oil pressure.
twin 60mm a pilar gauge holder
Greddy turbo timer
Greddy Profec b spec 2 boost controller
Polished cambox, throttle body, intake manifold, water pipes.
The block will have a rebore to take the new pistons
the head will be match port and polished, then shimmed to take the cams
Balenced crank.
Body work
new veilside C2 front bumper
paint skirts
Fit veilside rear spats
paint trd rear spoiler
paint or leave abflug carbon bonnet (not sure yet)
Got me work cut out by the looks of it need it ready for this years modbal event taking place in june, Like to say a big thanks to andy at Miami GT for getting most of the bits and to all for you input ;) ill keep your updated with pics and progress
john
  • Replies 91
Cheers I have a spare engine that has covered 40k from the aero top i am breaking I will be using this for the rebuild so I can still use the supra for work, once the block is ready I will swap engines. the block crank and head are off to be machined next week as soon as they are back I will start the rebuild
BLT67 this is how it arrived
Spent a few hours to get it like this but well worth the effort, I have blended the 90deg elbow in to make it look part of the turbo
The spare engine
started to strip it
All stripped ready to be machined
Polished the cambox covers and modified the water pipe cutting of the two spigots that go to the twin turbo set up then building it up with weld reshaped it to allow me to fit my apexi water temp sender
