Fuel pump installation.
Jake
Today, well yesterday now, I fitted a Walbro GSS342 fuel pump that I got from Paul E. It all fitted ok and the car's running great but I'm a little concerned about a couple of things.
The electrical connector socket on the new pump was a different shape to the one I removed, so I cut off the plug and soldered on the new plug that came with the pump. I wasn't really sure how to insulate the bare metal connections I'd made so I used two sections from a plastic connector block, like this . . .
http://www.tlc-direct.co.uk/Images/Products/size_3/TLCON2X.JPG
. . . even though the wires were actually soldered together, it was just as a way of ensuring that the live wire couldn't somehow touch an earth. I figured that sticky electrical tape wouldn't be any good submerged inside a fuel tank.
Also, I used a cable tie to hold the pump body to its metal bracket because the standard arrangement didn't seem all that secure to me.
But now I'm wondering if I did a stupid thing by putting these plastic bits inside the fuel tank. Some sorts of plastic get disolved by petrol don't they? So, should I removed these things? If so, what should I used to shield the bare wire where I did my soldering?
Thanks
Jake
Its best to use the connectors that come with the Walboro , even heat shrink dissolves in petrol then the wires touch together (ask Paul E) , its also a good move to stagger the connection so this cant happen .
Dude :flame Dev
Originally posted by dude
Its best to use the connectors that come with the Walboro , even heat shrink dissolves in petrol then the wires touch together (ask Paul E) , its also a good move to stagger the connection so this cant happen.
It didn't come with anything for joining the wires or insulating the joints, should it have come with some?
I'm confident that the joints I've made are safe, just as long as the plastic connector block doesn't dissolve in the petrol.
Originally posted by Ian C
I used a terminal block :)
No probs for nearly two years, and I had the pump out earlier this year and everything is un-melted and tight.
http://www.blackhorsedesign.com/artworks/aboutartist/phew.gif That's a weight off my mind.
cheers mate
