Chris Wilson Posted February 13, 2007 Share Posted February 13, 2007 If so could you do me a quick favour please? To save me making gaskets or generally pratting about, could you post up the page showing the back of the water pump, where the rear housing attatches. There is an elbow on the rear housing, on a none race engine I suspect it houses the thermosta. i need th part number for the gasket there. Thanks. Mr2 MK1 or Corolla 1600 DOHC models should have this bit. Link to comment Share on other sites More sharing options...
merckx Posted February 13, 2007 Share Posted February 13, 2007 Is this the one? The main housing in the 1st pic bolts onto the side of the rear water pump housing. - see the 2nd pic. The gasket in the pic is 16325-63011 Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 14, 2007 Author Share Posted February 14, 2007 Thanks for looking, unfortunately this doesn't look like the same back plate unit. I have put a photo of mine at http://www.chriswilson.tv/pump.jpg bear in mind that two unions are blanked off on this, they may have gone to heater hoses or elsewhere. One is blanked with a plate (left) with two bolts, one is blanked by an internal plug (top) Thanks. Link to comment Share on other sites More sharing options...
merckx Posted February 14, 2007 Share Posted February 14, 2007 This is the nearest I can find , different orientation though -Toyota Corona? Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2007 Author Share Posted February 15, 2007 Damn, I hope I haven't put you out. None of those are the same, very odd, I will just make a couple of gaskets, it's proving a PITA to find the OE part number, thanks for all your trouble. Link to comment Share on other sites More sharing options...
merckx Posted February 15, 2007 Share Posted February 15, 2007 No trouble at all, I was bored. Link to comment Share on other sites More sharing options...
