Anyone got an EPC loaded showing 4-AGE Corrolla / MKI MR2???
Chris Wilson
If so could you do me a quick favour please? To save me making gaskets or generally pratting about, could you post up the page showing the back of the water pump, where the rear housing attatches. There is an elbow on the rear housing, on a none race engine I suspect it houses the thermosta. i need th part number for the gasket there. Thanks.
Mr2 MK1 or Corolla 1600 DOHC models should have this bit.
Thanks for looking, unfortunately this doesn't look like the same back plate unit. I have put a photo of mine at http://www.chriswilson.tv/pump.jpg
bear in mind that two unions are blanked off on this, they may have gone to heater hoses or elsewhere. One is blanked with a plate (left) with two bolts, one is blanked by an internal plug (top) Thanks.
