tDR Posted February 25, 2007 Share Posted February 25, 2007 Nothing from other manufacturers that's similar in that it comes in a neat din sized package? Can you give me a price for the unit above and is it only green or amber backlighting? Also, do you get the related senders and a sandwich plate adapter for easy fitment of oil temp and pressure senders? Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 25, 2007 Share Posted February 25, 2007 Nothing from other manufacturers that's similar in that it comes in a neat din sized package? No nothing similar that I know of. Defi do the Link Display that is small enough to fit in the DIN slot, this can display all readings, some of the sensors need to be purchase separately. http://www.nippon-seiki.co.jp/defishop/product/dp/dp_top.html Can you give me a price for the unit above and is it only green or amber backlighting? Available with white/green, black/green or black/red display see pics here. http://www.nippon-seiki.co.jp/defishop/product/din/din_type.html Also, do you get the related senders and a sandwich plate adapter for easy fitment of oil temp and pressure senders? The DIN Gauge includes the sensors and harnesses. It does not include a sandwich plate. Quote Link to comment Share on other sites More sharing options...
imi Posted February 25, 2007 Share Posted February 25, 2007 pics fitted: Fit was great. Obviously not all wired up yet http://i73.photobucket.com/albums/i218/Cawdell/2-3.jpg http://i73.photobucket.com/albums/i218/Cawdell/1-4.jpg http://i73.photobucket.com/albums/i218/Cawdell/3-3.jpg TOP JOB ED...looks very nice. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted February 25, 2007 Author Share Posted February 25, 2007 TOP JOB ED...looks very nice. thanks mate Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted February 25, 2007 Author Share Posted February 25, 2007 Brian, The unit includes everything needed. Fitting the display was really easy. Used the original DIN space in the car and the kit includes different screw for different mounting options. Also, the instrustions are very comprehensive and easy to follow in engwish. Quote Link to comment Share on other sites More sharing options...
tDR Posted February 25, 2007 Share Posted February 25, 2007 Yep but oil temp will mean drilling a hole in your oil sump to mount that sensor and oil pressure means taking a T off the stock oil pressure switch... such T's are notorious for fracturing and pissing your oil everywhere. Hence a sandwich plate adapter (mounts between the block and stock oil filter and has a take off for each sensor) is a neat and hassle free way of taking care of both. I wonder if the GReddy sandwich plate would work with Defi sensors? Nic, is it possible just to buy and run the D-Link Display, Control Unit II and sensors without the need for gauges everywhere? I'm guessing the display once configured will alert in some way if any entered parameter is exceeded, drawing your attention to it? If so, what sort of cost is involved in such a setup? Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 25, 2007 Share Posted February 25, 2007 I wonder if the GReddy sandwich plate would work with Defi sensors? Yes it should do. Nic, is it possible just to buy and run the D-Link Display, Control Unit II and sensors without the need for gauges everywhere? Yes you can run the Link Display without the gauges. I'm guessing the display once configured will alert in some way if any entered parameter is exceeded, drawing your attention to it? Yes there is an LED warning light that will show if the set levels are exceeded. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted February 25, 2007 Share Posted February 25, 2007 No nothing similar that I know of. Defi do the Link Display that is small enough to fit in the DIN slot, this can display all readings, some of the sensors need to be purchase separately. I love the Link Display, It doesn't display boost though for some stupid reason... Gaz Quote Link to comment Share on other sites More sharing options...
