NOT boosting!!
Ibrar Jabbar
This evening I managed to find some time to re-connect my boost guage, I then took the Sup out for a blast and noticed that I cannot boost beyond ~14 PSI, It seems as if the 2nd turbo is not boosting!!
Does anybody know the symptoms?
all help appreciated, cheers
PS. fully de-catted, HKS drager, VFCC
UK Spec may not boost beyond 14psi with the cats out. My J spec only hits 14psi as well. I did have a old worn out Blitz BOV which was leaking pressure but that only added 2psi... Check that all of you pipe work is secure.
I assume you checked the connections for your boost gauge
I noticed that mine whistles quite loudly when, I think, number 1 starts to spool and continues until I can't hear it any more 'cos of wind/road noise.
Is this normal, bearing in mind I'm going to be looking at why mine pulls like a train to 120 and then falls off to 125 max (no popping and stuttering of a limiter)?
I ended up fitting a J-spec manifold and turbos in the end, It seems as if the second turbo isn't boosting! at 4500 RPM.
All pipes / hoses look OK.
With the previous manifold and turbos I was boosting to 18 PSI.
Could it be the actuators or the wastegate faulty on the replacement manifold?
Any thing else I should check?
I want to get it all sorted before I advertise it. Cheers
(Edited by Ibrar Jabbar at 6:46 pm on Aug. 8, 2001)
Just to let You all know, I have sorted the boosting problem, it seems as if, I was loosing pressure through the bottom intercooler hose.
Tightened up the clip with a 10mm socket, double checked all other pipes and clips.
Took the car out for blast and hit 18 PSI in 3rd, so all is fine know :-)
