Ibrar Jabbar Posted August 7, 2001 Share Posted August 7, 2001 This evening I managed to find some time to re-connect my boost guage, I then took the Sup out for a blast and noticed that I cannot boost beyond ~14 PSI, It seems as if the 2nd turbo is not boosting!! Does anybody know the symptoms? all help appreciated, cheers PS. fully de-catted, HKS drager, VFCC Link to comment Share on other sites More sharing options...
Guest Ash Posted August 8, 2001 Share Posted August 8, 2001 Was it working okay *before* the time you say you found to re-connect the gauge? Yours, J Link to comment Share on other sites More sharing options...
Alex Posted August 8, 2001 Share Posted August 8, 2001 UK Spec may not boost beyond 14psi with the cats out. My J spec only hits 14psi as well. I did have a old worn out Blitz BOV which was leaking pressure but that only added 2psi... Check that all of you pipe work is secure. I assume you checked the connections for your boost gauge Link to comment Share on other sites More sharing options...
Paul Booth Posted August 8, 2001 Share Posted August 8, 2001 I noticed that mine whistles quite loudly when, I think, number 1 starts to spool and continues until I can't hear it any more 'cos of wind/road noise. Is this normal, bearing in mind I'm going to be looking at why mine pulls like a train to 120 and then falls off to 125 max (no popping and stuttering of a limiter)? Link to comment Share on other sites More sharing options...
Branners Posted August 8, 2001 Share Posted August 8, 2001 Ibrar, you fitted UK turbos and manifold didnt you? The UK spec has some sort of bypass pipe or a better wastegate or something which stops it overboosting so to get more boost you are going to need to turn up the boost controller if you have one. JB Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted August 8, 2001 Author Share Posted August 8, 2001 I ended up fitting a J-spec manifold and turbos in the end, It seems as if the second turbo isn't boosting! at 4500 RPM. All pipes / hoses look OK. With the previous manifold and turbos I was boosting to 18 PSI. Could it be the actuators or the wastegate faulty on the replacement manifold? Any thing else I should check? I want to get it all sorted before I advertise it. Cheers (Edited by Ibrar Jabbar at 6:46 pm on Aug. 8, 2001) Link to comment Share on other sites More sharing options...
Branners Posted August 8, 2001 Share Posted August 8, 2001 hmm, you would be hard pushed to get 14psi out of the first turbo, sounds like it might just be running in true twin mode due to a VSV problem. Best get it to somebody who knows what they are looking for. JB Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted August 12, 2001 Author Share Posted August 12, 2001 Just to let You all know, I have sorted the boosting problem, it seems as if, I was loosing pressure through the bottom intercooler hose. Tightened up the clip with a 10mm socket, double checked all other pipes and clips. Took the car out for blast and hit 18 PSI in 3rd, so all is fine know :-) Link to comment Share on other sites More sharing options...
