My Supra - Project Single Turbo 71mm
Supra71GTS_Ice
Here are some pictures that were taken this winter when my supra was being built :) I thought maybe you guys would like to see some pictures of the build ;)
Toyota Supra TT - 6speed Targa
Here is the mod list
Engine
BL71mm GTS 0.81 A/R Single Turbo
SUS321 Tig Welded Tubular Header
HKS 50mm SS Wastegate
4” Stainless Steel Downpipe
4” Stainless Steel Midpipe
4” Aluminum Intake Pipe with Anti-Heat Coating
4" Boost Logic Polished Exhaust
4" AEM Dry Flow Air Filter
PHR Stage 2 Complete Fuel System
PHR 17.5mm ID high flow fuel rail upgrade
-6AN Stainless Steel braided fuel lines
liquid-filled fuel pressure gauge
Siemens 850cc fuel injectors
Dual Walbro fuel pumps
Aeromotive EFI fuel pressure regulator)
HKS 264 Cams
Crower Springs and Retainers
Boost Logic Crank Pulley
HKS Racing Blow-Off Valve Type 2
Titan Motorsports Cam Gears
Greddy 3-Row FMIC
ARP Head Studs
Powerhouse Racing Polished Upper Radiator Pipe Kit(Red Silicone)
NGK Model 3330 Spark Plugs
Transmission
V160 6speed Getrag
RPS Stage 3 with 6-puck Sprung Hub Disc
Fidanza Flywheel
Electronics
AEM EMS(Engine Management System)
AEM Map Sensor - 3.5 bar
HKS DLI-2 Twin Power Ignition Amplifier
HKS EVC 5 - KPA Measurement (Electronic Boostcontroller)
PLX Devices R-500 Wide Band Kit
Blitz Dual turbotimer
AutoMeter 52mm Boost Gauge
Chassis
Lowering Springs
Cusco front and Rear Strut Bars
http://liveu-03.vo.llnwd.net/vidilife/image/2006/4/17/512026/1053603L.JPG
http://liveu-05.vo.llnwd.net/vidilife/image/2006/4/17/512026/1053605L.JPG
http://liveu-35.vo.llnwd.net/vidilife/image/2006/4/17/512026/1053835L.jpg
http://liveu-38.vo.llnwd.net/vidilife/image/2006/4/17/512026/1053838L.jpg
http://liveu-39.vo.llnwd.net/vidilife/image/2006/4/17/512026/1053839L.jpg
http://liveu-44.vo.llnwd.net/vidilife/image/2006/4/17/512026/1053844L.jpg
http://liveu-41.vo.llnwd.net/vidilife/image/2006/4/17/512026/1053841L.jpg
http://liveu-26.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064726L.jpg
http://liveu-30.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064730L.jpg
http://liveu-37.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064737L.jpg
http://liveu-41.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064741L.jpg
http://liveu-46.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064746L.jpg
http://liveu-49.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064749L.jpg
http://liveu-51.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064751L.jpg
http://liveu-56.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064756L.jpg
http://liveu-65.vo.llnwd.net/vidilife/image/2006/4/17/512026/1064765L.jpg
http://liveu-48.vo.llnwd.net/vidilife/image/2006/4/17/512026/1066148L.jpg
http://liveu-56.vo.llnwd.net/vidilife/image/2006/4/17/512026/1066156L.jpg
http://liveu-59.vo.llnwd.net/vidilife/image/2006/4/17/512026/1066159L.jpg
http://liveu-64.vo.llnwd.net/vidilife/image/2006/4/17/512026/1066164L.jpg
http://liveu-98.vo.llnwd.net/vidilife/image/2006/4/17/512026/1072998L.jpg
http://liveu-99.vo.llnwd.net/vidilife/image/2006/4/17/512026/1072999L.jpg
http://liveu-04.vo.llnwd.net/vidilife/image/2006/4/17/512026/1073004L.jpg
http://liveu-07.vo.llnwd.net/vidilife/image/2006/4/17/512026/1073007L.jpg
http://liveu-11.vo.llnwd.net/vidilife/image/2006/4/17/512026/1073011L.jpg
http://liveu-15.vo.llnwd.net/vidilife/image/2006/4/17/512026/1073015L.jpg
http://liveu-21.vo.llnwd.net/vidilife/image/2006/4/17/512026/1073021L.jpg
http://liveu-28.vo.llnwd.net/vidilife/image/2006/4/17/512026/1073028L.jpg
http://liveu-30.vo.llnwd.net/vidilife/image/2006/4/17/512026/1073030L.jpg
http://liveu-82.vo.llnwd.net/vidilife/image/2006/4/17/512026/1079182L.jpg
http://liveu-85.vo.llnwd.net/vidilife/image/2006/4/17/512026/1079185L.jpg
http://liveu-19.vo.llnwd.net/vidilife/image/2006/4/17/512026/1079219L.jpg
http://liveu-23.vo.llnwd.net/vidilife/image/2006/4/17/512026/1079223L.jpg
http://liveu-26.vo.llnwd.net/vidilife/image/2006/4/17/512026/1079226L.jpg
http://liveu-30.vo.llnwd.net/vidilife/image/2006/4/17/512026/1079230L.jpg
http://liveu-16.vo.llnwd.net/vidilife/image/2006/4/17/512026/1079216L.jpg
Nice pics. Thanks for sharing.
It's a great feeling when you've got a load of new bits in boxes like that isn't it?
Even better when they're working harmoniously together. A nice sleeper.
hehe yeah it´s the same feeling you had when you were little on Christmas :D
There is some vids in this thread, post 17;)
http://www.mkivsupra.net/vbb/showthread.php?t=96377
Hehe thx for posting it :)
but here are direct links to both videos
Testing on low boost 16 psi :)
Some flames when hitting the rev limiter(4800rpm)
nice setup, who is tuning it for you ??. i have almost the same setup , but with a greddy intake/ 1000cc injectors . if you need a hand with the map , i can help...
It´s in storage now so it hasn´t been tuned completely
But Justin Nenni @ Tuning Concepts made me a map and sent it to my to work with :)
can you send me a pm or something and tell me your MSN ? that is if you use MSN ;)
