Firewall Help
Paul Laing
Hi, i'm busy doing my boost controller install but having problems with getting the harness through the firewall and into the engine. I have a UK manual, is there any good easy ways? On the guide i have it says go through the yellow grommet next to the clutch, but i can't see where this comes out at in the engine bay.
Any help on this?
Cheers lads,
Paul
The grommet I used is on the drivers side, up on the right hand side of the footwell. I found the best way is to push the wires from inside the cabin through the yellow grommet and then hook them from inside the engine bay using a coat hanger. If you look in the engine bay, down the drivers side wing on the inside you should be able to see the wire pushed through.
HTH
