saab
hulse
Assuming it's a 9000 Aero you are talking about (the 9-5 might be different), then it uses Saab's VSS (Vehicle Security System).
The alarm isn't really built into the ECU, but the two have to be able to talk for the vehicle to run.
You can swap ECU/VSS, but then you need a Saab garage/Specialist with the Tech2 interface to tell them to get along and let your car start.
More information can probably be found with a search at http://www.saabscene.com
for only a second post, that's pretty damn helpful chap, well done.
welcome by the way :)
