rik Posted February 11, 2007 Share Posted February 11, 2007 For some reason the rad fan on my car has recently been coming straight on as soon as the ignition is switched on. Even before the engine is running, as soon as the key is turned it sounds like a hovercraft starting up. My car is not on the road at the moment, and has only been started every now and then to move it around. Also the battery has been on/off a lot. Any body know why this is? Quote Link to comment Share on other sites More sharing options...
Ric Posted February 11, 2007 Share Posted February 11, 2007 locate the plug for the fan, its attached to the radiator itself, (bottom nearside) if the plug isn't there it will spin all the time, just reattach it to the sensor and it should only come on when its reaches a certain temp. Quote Link to comment Share on other sites More sharing options...
rik Posted February 11, 2007 Author Share Posted February 11, 2007 Cool, i'll go have a look. Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted February 11, 2007 Share Posted February 11, 2007 Mine started doing this too, It was on all the time (even with the ignition off) I managed to stop it as one of the relays under the passenger side headlight had blown. However now it doesn't ever come on I suspect the radiator switch went at the same time. Mike Quote Link to comment Share on other sites More sharing options...
buster Posted February 16, 2007 Share Posted February 16, 2007 i got a n/a and my fan just siezed up today it one of them that go on the fan belt where do i get a new one from please help!!!!!! Quote Link to comment Share on other sites More sharing options...
