leaky aerotop roof what seals
supradibbs
We normally spray both the front and rear rubbers with (Halfrauds)
Rubber Lubricant - i'll get exact name in morn' . . it's in garage !
It worked STRAIGHT AWAY !
The rain used to dribble down the front joins where they meet the
window MOSTLY.
Soon as we sprayed it, it 99% cured it !! It must expand the
rubber slightly or something and give a better 'mating' or sumtin' ??
Carole says "are you getting a wet ar*e then ?" :)
thaTS EXACTLY THE PROBLEM I HAVE
oh and no wet arse lol just the car has been standing a while and stinks off milldrew and stuck it through the car was earler and noticed it running out off the corner at the front near the a pillar when i brought it the guy said he thinks it may have had new seals so i will try lubing em up see how i get on
i am sure Nic can get these
I sure can :)
This is the list of all the seals I believe
63251-14050 WEATHERSTRIP,REMOVABLE ROOF,FRONT
63252-14020 WEATHERSTRIP,REMOVABLE ROOF,REAR
62383-14030 WEATHERSTRIP,ROOF SIDE RAIL,LH
62384-14030 WEATHERSTRIP,ROOF SIDE RAIL,RH
63217-14030-C0 MOULDING,REMOVABLE ROOF,RH
63218-14020-C0 MOULDING,REMOVABLE ROOF,LH
If anyone needs a source for new parts let em know.
http://img299.imageshack.us/img299/9582/jza80roofsealks2.jpg
