supradibbs Posted February 10, 2007 Share Posted February 10, 2007 my aerotop roof appears to be leaking slightly what seals require changing anyone had this problem Quote Link to comment Share on other sites More sharing options...
Steve W Posted February 10, 2007 Share Posted February 10, 2007 We normally spray both the front and rear rubbers with (Halfrauds) Rubber Lubricant - i'll get exact name in morn' . . it's in garage ! It worked STRAIGHT AWAY ! The rain used to dribble down the front joins where they meet the window MOSTLY. Soon as we sprayed it, it 99% cured it !! It must expand the rubber slightly or something and give a better 'mating' or sumtin' ?? Carole says "are you getting a wet ar*e then ?" Quote Link to comment Share on other sites More sharing options...
supradibbs Posted February 10, 2007 Author Share Posted February 10, 2007 thaTS EXACTLY THE PROBLEM I HAVE oh and no wet arse lol just the car has been standing a while and stinks off milldrew and stuck it through the car was earler and noticed it running out off the corner at the front near the a pillar when i brought it the guy said he thinks it may have had new seals so i will try lubing em up see how i get on Quote Link to comment Share on other sites More sharing options...
Steve W Posted February 10, 2007 Share Posted February 10, 2007 We've only ever tried the Hallies one, but can't see why any other make shouldn't work ?? BUT, still let ya know what it's called in morn' (too lazy/old to go out there now ) Quote Link to comment Share on other sites More sharing options...
TrickTT Posted February 11, 2007 Share Posted February 11, 2007 I brought a new front seal (up the a-posts and across the front of the roof) from toyota last year. Cost less than £70. Quote Link to comment Share on other sites More sharing options...
tichkent Posted February 11, 2007 Share Posted February 11, 2007 I had exactly that problem when I got my Aerotop last year. Thanks to advice on this forum, a good spray of silicone lubricant (Halfords, about £4) solved the problem completely. I keep checking the seats after heavy downpours but all nice and dry now Quote Link to comment Share on other sites More sharing options...
supra steveo Posted February 11, 2007 Share Posted February 11, 2007 i am sure Nic can get these Quote Link to comment Share on other sites More sharing options...
Konrad Posted February 12, 2007 Share Posted February 12, 2007 Also check front screws on roof, mine was just slightly loose and water was getting onto seats. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 12, 2007 Share Posted February 12, 2007 i am sure Nic can get these I sure can This is the list of all the seals I believe 63251-14050 WEATHERSTRIP,REMOVABLE ROOF,FRONT 63252-14020 WEATHERSTRIP,REMOVABLE ROOF,REAR 62383-14030 WEATHERSTRIP,ROOF SIDE RAIL,LH 62384-14030 WEATHERSTRIP,ROOF SIDE RAIL,RH 63217-14030-C0 MOULDING,REMOVABLE ROOF,RH 63218-14020-C0 MOULDING,REMOVABLE ROOF,LH If anyone needs a source for new parts let em know. http://img299.imageshack.us/img299/9582/jza80roofsealks2.jpg Quote Link to comment Share on other sites More sharing options...
supra steveo Posted February 12, 2007 Share Posted February 12, 2007 i think i need to start working out the commission Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted February 12, 2007 Share Posted February 12, 2007 I had a problem with my drivers side seal. It dripped in mainly whilst driving. It turned out to be a badly adjusted drivers door window. Quote Link to comment Share on other sites More sharing options...
