2 things that I need clearing up.....
Suprash
Ok just a quick couple of questions, firstly is the NA clutch the same as a TT clutch, can they be swapped around ???
How much torque does a standard NA clutch hold ???
Im also wanting to find out who is running naaawws (NOS) on their car, pretty sure there was a NA out there already.
Also I need someone to work out the following diad code for the air con. While holding down both buttons and then turning on the ignition after all the lights across the controls light up (pre test ???) I then get 2 flashing lights continuosly above the Auto/FAN button I think, one of the buttons.
Any help on the above would be great..... :D
Jamin had his regassed by a local bloke who came out to his house and fixed it, also checked the whole system out for him including a leak test etc.
Really good by the sound of it, send him a PM for the number, I'll text him to see if he's still got in the mean time.
Hi Ash,
I'm told Paul E has some new thingamejig NO2 marketed specifically for the NA - he may be able to give you the advice you require.
