Group Buy Request - Custom Speaker Brackets
Sheefa
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
4.Chris and Alana? (MR-MDF)
5.Toyo Rob - depending on size MR-MDF (extra cost to re-jig machine of £8.50)
6.Jake (PLEASE STATE)
7.Ant (PLEASE STATE)
8.Flip (ABS)
9. edd_t (PLEASE STATE)
10. ~Rob~ (PLEASE STATE)
11. Johnnyknox (ABS)
12. evanshaw (MR- MDF)
13. Rob Dublin (ABS)
14. jamesmark (MR-MDF)
15. SkinnBa (MR-MDF)
  • Replies 141
I have a cnc at work and more mdf than I can shake a stick at, but ABS :cool:
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
Good choice Muffleman. The supplier said I need 10 ABS to produce these. I think they'll be much stronger and easier to fit to be honest with a more rigid futureproof base.
Doesn't matter on the number of MDF, but obviously 20+ to make the total 30. :)
Guest Skidracer
Uh.. Does it matter that I haven't bought a membership yet? :help:
If not, Id like a set! Preferably ABS, but if that's not possible, mr-mdf with poly sealant is ok :)
Also, does a similar product exist for the backseat speakers?
Guest Skidracer
As long as I can contact you Skid no problem mate. Pay for membership though pal if I was you - best tenner you'll ever spend! ;)
Allright !
I was going to become a member all along, just haven't gotten around to it yet :)
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
17. SkidRacer (PLEASE STATE)
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
18. suprasteve (MR-MDF)
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
19. Lebsteif (MR-MDF)
I'll have a set
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
20. Gee (MR-MDF)
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
Guest Nicholas
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
22. Supranick (ABS)
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
22. Supranick (ABS)
23. Adam5284 (MR-MDF)
put me down for a set.il have mdf.nice one:)
Most people cut and paste mate - like I have done below ;)
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
22. Supranick (ABS)
24. Timalbert (MR-MDF)
The more the better I say! We need approx 3 more for the ABS style though, but I can always order a few more and keep them in storage for other members who may want some later. :)
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
22. Supranick (ABS)
25. Bolarbag (ABS)
p.s are these things light or heavy? I'll buy a set of the abs ones for a laugh anyway!;)
Sheefa
Just wanna say thanks mate, you're putting a lot of effort into this. :thumbs:
Yep, I echo this. Top work Sheefa, it hasn't gone un-noticed!
The only thing that holds me back about the ABS is whether it'll be as easy to modify to suit the particular speakers that I eventually buy. For example, do you know if ABS is as "drillable" as MDF (without cracking it)? As you can guess, I know absolutely nothing about ABS.
I'm tempted to change mine to an ABS order.....
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
10. ~Rob~ (MR-MDF)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
22. Supranick (ABS)
25. Bolarbag (ABS)
Thanks guys!:blush: That's what the community is all about though!
Stevie - I understand your concerns mate and I've emailed Phil for a proper response. I had the same. But see below for a bit of info around the material pal.
Phil said he could drill holes in ready for the speakers to be mounted, but of course all speakers differ in terms of where the holes are located so this would cause more harm than good! :)
"ABS has been hailed by professional modelmakers as “the best all-around construction material since wood”. Stronger and more rigid than many metals; easier and more flexible to work with than any previous plastic; cleaner and more durable than wood. ABS is also one of the best plastics for heat or vacuum forming and, of course, has excellent bonding characteristics, not only to itself but to other commonly used plastics. ABS has just the desired amount of flexibility to minimize shock.
ABS is a thermoplastic terpolymer combining the best qualities of the Acrylics, Butyrates, and Styrenes. It is more than half again as rigid as its cousin, Styrene, and size for size, is nearly as rigid as brass. Extremely resistant to most acids and alkalies, the ABS lustrous surface is unaffected by most chemicals, even lacquer - a property unheard of in the early plastics. Unlike wood and brass, PLASTRUCT ABS Traditional Structural Shapes require no priming, sanding, or sealing to enhance its hard finish. But like even the most primitive plastics, ABS bonds easily, quickly, and with a minimum of fuss.
Plastic can be sawed, blade cut, drilled, lathe-turned, carved, sanded and filled. Most standard woodworking tools may be used on plastic and it will not splinter. Plastic parts join in seconds with small amounts of liquid solvent cement. For bonding plastic sheet materials to foam, wood or Masonite, Contact Cement can be used. For large sheet stock, many professionals prefer to use counter sunk screws for attachment. A spray adhesive is sometimes easier for small jobs".
Hope this helps. ;) I'll find out more from Phil tomorrow.
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
10. ~Rob~ (MR-MDF)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
22. Supranick (ABS)
25. Bolarbag (ABS)
26. Colsoop (ABS) please
Guest sunnyG83
1.Sheefa (ABS)
2.Stevie_b (MR-MDF)
3.m45sey (MR-MDF)
8.Flip (ABS)
10. ~Rob~ (MR-MDF)
16. Muffleman (ABS)
20. Gee (MR-MDF)
21. konio-nt (ABS)
22. Supranick (ABS)
25. Bolarbag (ABS)
27. SunnyG83 (ABS) ta
