Chris Wilson Posted February 8, 2007 Share Posted February 8, 2007 I need to get my Skyline through an MOT and I suspect they'll want to see operating front indicators My I/C pipes preclude me putting the stock bulbs and their holders in the front indicator lens housings, I was thinking of securing a high brightness LED in each housing using Sikoflex, and wiring a connector to an extension of their pigtails. My worry is can you get white ones, as the lamp housing lenses give the amber colour? Will the very low current draw of an LED stop the flasher unit from working properly, as if a buld had failed? If so can I use a resitor or even parallel the LED with a hidden 21 watt 12 volt bulb to create the load? Where can I buy high brightness, 12 volt white light LEDs by mail order? Thanks. It's only to get through the test, the install doesn't have to last 100K miles! Quote Link to comment Share on other sites More sharing options...
Pete Posted February 8, 2007 Share Posted February 8, 2007 Motorbike ones? I think you can buy them in strips too. Can't find the link though. Quote Link to comment Share on other sites More sharing options...
Pete Posted February 8, 2007 Share Posted February 8, 2007 Like these sort of - http://www.superbrightleds.com/light_bars.htm Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted February 8, 2007 Share Posted February 8, 2007 These ( http://www.priracing.com/product.php?xProd=1503&xSec=13&jssCart=9ea7879bec4b7f93a017ea363346e83b ) are nice - a little expensive though!!!!! Quote Link to comment Share on other sites More sharing options...
uk-rich Posted February 8, 2007 Share Posted February 8, 2007 These ( http://www.priracing.com/product.php?xProd=1503&xSec=13&jssCart=9ea7879bec4b7f93a017ea363346e83b ) are nice - a little expensive though!!!!! these are seriously bright, as white as hid, i have them,but didn't pay that much Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted February 8, 2007 Share Posted February 8, 2007 if you install normall high brightness LEDs they will flash quickly so you will need a resistor to go with them, obviously fitted across the led. Quote Link to comment Share on other sites More sharing options...
G-NEMIE Posted February 8, 2007 Share Posted February 8, 2007 http://www.ultraleds.co.uk/ Quote Link to comment Share on other sites More sharing options...
