Anyone seen 2JZ-GTE forged pistons with cooling channels?
Chris Wilson
The stock MKIV TT pistons are cast with a cooling gallery in the crown, like Skyline ones, fed with oil from a fairly large oil squirter hole in the con rod. All the forged ones I have yet to see haven't got this gallery. I found Tomei ones for my own Skyline engine that are forged, and have a cooling gallery. They don't do Toyota ones thaogh. I am 90& sure they don't exist, which is a shame as they remove a LOT of heat very effectively. Anyone seen any?
2JZ at bottom
http://www.tomei-p.co.jp/_2003web-catalogue/058_EJ22_piston.html#2JZ
And explanation of oil cooling proporties..
http://www.tomei-p.co.jp/_2003web-catalogue/050-051_piston.html
You'l need to google-translate
I don't think the Tomei 2JZ-GTE are available with cooling channels.
I have the English vesrion of the cooling channel info at:
http://www.chriswilson.tv/tomei/efr_index.html
Hmm how much do the Tomei's weigh?
My Skyline RB26 ones at 86.5 mm, with cooling channels, were 475 grammes from the factory, with titanium coated rings and pins fitted. I got them down to 430 grammes by machining and hand finishing. I could get more off them with modern tapered pins, but didn't go that far.
I can find no reference to Toyota 2JZ-GTE pistons on their current site, using the English option, sorry.
