merckx Posted July 1, 2004 Share Posted July 1, 2004 Anyone know where to get some instructions and a wiring diagram for a Sigma M30 Alarm. I've just bought a communications module that will ring me up if my alarm goes off, but I need to find a pager output from the alarm. I've also got a keypad fitted with the Sigma Alarm but I don't have the code. Any help much appreciated. Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 1, 2004 Share Posted July 1, 2004 I should be able to help you with this. I'll be in touch once later this morning. Link to comment Share on other sites More sharing options...
michael Posted July 1, 2004 Share Posted July 1, 2004 I had one of those, very robust system - sadly I can't help with any of the info you need as I gave all my docs away with the car - however if you find out how to reset the code can you PM me - I changed mine to something I'd remember and then forgot it - the default used to be 1234 though. Link to comment Share on other sites More sharing options...
SkyJawa Posted July 1, 2004 Share Posted July 1, 2004 All Scoobies are fitted with them, as was my old dead supe, I have the manual at home.................. Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 1, 2004 Share Posted July 1, 2004 The wire you'd need to connect to on an M30 would be the Green/Orange. This gives a low current negative output when the alarm triggers. As for pin code change, I can do it via one of my programmers (CP1), but my book doesn't tell me how to do it via the keypad. I will find out for you though, and send you a PM. (Both of you). I won't publish it on the BBS for obvious reasons. Link to comment Share on other sites More sharing options...
merckx Posted July 1, 2004 Author Share Posted July 1, 2004 Great - Green / Orange wire it is. Thanks for the help Matt My communications module also has an input for the alarm status , it must need to know whether the Sigma Alarm is armed or disarmed. Any ideas which one this would be? Cheers Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 2, 2004 Share Posted July 2, 2004 Yep, Green/Black. Link to comment Share on other sites More sharing options...
merckx Posted July 2, 2004 Author Share Posted July 2, 2004 Thanks again Matt Should be able to get my communications module fitted now. The wiring for the alarm isn't particularly easy to get at but I shouldn't have any problems. Cheers Link to comment Share on other sites More sharing options...
paulfurn Posted July 2, 2004 Share Posted July 2, 2004 Does anyone know where I can purchase one of these modules from? My fiancee has an FTO with that alarm, but I dont think it had the module. It would be nice to add it to her alarm if possible, as she is a nurse and often works nights. As such she is petrified of her car getting broken into or worse in the hospital car park. I guess this would help ease the worry a bit. Link to comment Share on other sites More sharing options...
merckx Posted July 2, 2004 Author Share Posted July 2, 2004 You can buy the communications module at: Here Almost got mine working, having a few problems with not knowing what telephone code to use for my mobile. Link to comment Share on other sites More sharing options...
